Thiessen Polygons - polygon input
3266
10-22-2020 11:31 AM
DavidPike
MVP Notable Contributor
ArcMap x.x / Pro x.x
Thiessen/Voronoi/Dirichlet...
Hi all,
Would the process for thiessen polygon generation be the creation of a load of points on the polygon boundaries, add an identifying attribute to each point belonging to polygon, run the 'create thiessen' tool, then dissolve the thiessen polys based on ID field?  I'm trying to work this in my head - would just the vertices to points be OK? Is there a better way and am I potentially missing an error here?
Cheers!
DanPatterson
MVP Esteemed Contributor
convert to polygons to points perform your choice of triangulation, then use the Erase tool to produce the hole, then either leave them empty or merge the polygons back.
Makes good stained glass patterns
... sort of retired...
DanPatterson
Are you trying to triangulate the interior of polygons or the intervening space between poly* points? like these examples in my toolset?
https://community.esri.com/people/danretired/blog/2020/06/16/free-advanced-tools-thiessen-polygons-d...
DavidPike
Hi Dan,
No, excluding the interiors if there were any, more like just treating the polygon as a solid block, then expanding out from it.  Any inner mischief should get cancelled out in the final dissolve (I would guess).  I really need to test it rather than talk about it I think...
Cool outputs though!
DanPatterson
