Report Designer Issue - Grouped fields
1666
03-06-2017 01:50 PM
deleted-user-VvvLP0IsAqjw
When I create a report based on multiple group fields, the report runs fine, but when I save an RLF and try to run the report later, the grouping is not honored.
  • ArcGIS 10.4.1 (5686) - Advanced
Basically Steps (shown in attachment)
  1. Join two tables (1-n).
  2. Group on three fields
    • Date (by YEAR)
    • Color
    • Type
  3. Sum at then end of the Type group
    • Gallons
    • Applied
  4. Run the Report - It is fine
  5. Save the Report - reload (same MXD)
  6. Run again - The report no longer honors grouping
It seems like a bug.
Also, does anyone know if the default Report Wizard is the same in the Business Analyst extension? Is that a more "mature" version of the Report Designer?
TIA,
Susan
In case anyone runs into this....
This was verified to be a bug - Esri Case #01901700 - Report Designer Bug
  • Date (by YEAR)  - Grouping a date field does not work - have to break the YEAR out as a field in the table.
Susan
Susan
