I'm projecting a shapefile currently supplied in ETRS89 format to OSGB 1936 in ArcGIS 10.4.1. I have followed the advice given by ESRI UK (Adding the new OSTN15 NTv2 transformation — Esri UK ) to ensure that the latest transformation is available. I have downloaded the transformation files, added them in my Arc directory as per the instructions, and can clearly see the files. However, when I use the project tool in ArcCatalog the transformation (OSTN15_NTv2_ETRStoOSGB) is not visible in the dropdown. Also if I manually type the name of the transformation into the dialogue box it will not be recognised by the tool. if I project without the transformation, my points are out by about 105m. Is there some sort of path issue such that Arc cannot find the transformation?
