I've tried a few examples giving to people asking a similar question , but haven't managed to get any of them to work using the field calculator.
I basically have a shapefile with a field named "d_material" which contains the following entries:
DI - Ductile Iron
HDPE - High Density Polyethylene
HPPE - High Performance Polyethylene
CI - Cast Iron
MDPE - Medium Density Polyethylene
SI - Spun Iron
uPVC - Unplasticised Poly Vinyl Chloride
It also contains Null/blank cells
I'm trying to use the field calculator to remove text so I only end up with:
DI
HDPE
HPPE
CI
MDPE
SI
uPVC
Blank fields stay blank
I know its possible, but haven't managed to get it working. Any help would be great thanks. I'm running ArcMap v10.2.1 for desktop.
Regards,
Thomas
