How to get time dimension for Sentinal-5P TROPOMI L2 NO2 netCDF recognized in mosaic dataset in ArcPro?
2618
04-17-2020 01:14 PM
SaraStrachan
I am loading netCDF files from L2 TROPOMI Sentinal-5P into a mosaic dataset in ArcPro. It is not recognizing the time dimension correctly. ArcPro seems to recognize time as a dimension, but not parse it correctly. The definition is ‘seconds since 2010-01-01 00:00:00’. The data are daily, so the time steps should be 86,400. As I am loading the netCDFs into the mosaic dataset, how do I define the time dimension correctly?
@Vinay Viswambharan
multidimensional‌
#netcdf
DawnWright
Attention Vinay Viswambharan
Dawn Wright (she/her/hers), Ph.D. & GISP | Esri Chief Scientist
HongXu
by Esri Contributor
Hi Sara, sorry for the late reply.
we made some fix in 2.6 and confirmed with S5P_OFFL_L2__NO2, S5P_RPRO_L2_NO2, S5P_NRTI_L2_NO2 products, please check out when 2.6 is released.
Hong
SaraStrachan
OK, I will. Thank you!
