Allow holes in ArcGIS Online Ground
254
09-02-2025 04:33 PM
Status: Open
Marc_Graham
Where we have complex BIM models that intersect with the ground, we need the ability to cut a hole in the Ground surface, similar to how ArcGIS Pro works.  Currently if there is a dem with a NoData area, this gets replaced with a default surface at 0 elevation.
I would suggest that there could be an option in the scene to turn this off, and ONLY display terrain where there are valid ground cells.  Additionally the ability to mask out parts of the ground in the same way we can mask out integrated mesh layers would be very useful. This would let us use publicly available elevation services as ground, and remove the bits we don't need, replacing them with our BIM models.
Marc
