Event Editor and ArcGIS Server versions
2303
8
02-02-2022 11:46 AM
AlexCarter1
Does the Event Editor version have to be kept in lockstep with the Server version you are using or can you use a newer version of Event Editor?
Currently using Server 10.8.1 for Portal, publishing with ArcGIS Pro 2.8.  Wondering if we can use 10.9.1 Event Editor.
CameronCole
Hey Alex,
I am not in the same boat as you are but I do not have them in "lockstep" I am running 10.5.1 Server and 10.8.1 Event Editor. Sorry this doesn't answer your question 100% but it shows that having them different still functions.
AlexCarter1
Cameron,
It answers it enough for me to be fairly certain it's possible.  Thanks for the reply!
NathanEasley
Hi Alex,
Yes this is possible, but we do recommend you keep your Enterprise and Event Editor versions in alignment whenever possible.  New functionality and bug fixes can be made in both Enterprise (via REST) or within Event Editor, so keeping them in alignment ensures you don't see functionality that doesn't work as expected.
Nathan
ArcGIS Roads and Highways team
AlexCarter1
Nathan,
Where is the best location to download previous versions of Event Editor to keep them in alignment?
CameronCole
Alex,
I was able to download the installation files for R&H (which ever version) then when you unpack it and start the installation you can just grab the Event Editor application files that would have gone into IIS. Then you can add the files to IIS and have the most recent config.json files for event editor.
Do not install the apps for server or desktop otherwise they will no longer work. You want just the IIS files for event editor.
I am sure there is a more eloquent way to say what I said. If it doesn't make sense I think I might have some screen shots from when I did it a few months back.
AlexCarter1
Got it, thanks!
CameronCole
Alex,
Just curious, what is your use case for needing to do this?
AlexCarter1
As Nathan said, they recommend to keep your Event Editor and Enterprise versions in alignment.  We are currently using Enterprise 10.8, so I wanted to make sure Event Editor was the same version.  Unless I am misinterpreting him.
