how to transfer as.Date in R to Date in ArcGIS
1828
05-16-2019 04:38 AM
RamB
how do I convert a as.Date of R to a Date in ArcGIS? The field is a date in the r data.frame, but when it is opened in arcgis, it is a character/ string type.
thank you.
Tags (1)
Egge-Jan_Pollé
Hi Srirama Bhamidipati‌,
You may want to use Python to convert the string in ArcGIS to a datetime object.
Does this Stack Overflow discussion python - Converting string into datetime - Stack Overflow answer your question?
datetime.strptime is the main routine for parsing strings into datetimes. It can handle all sorts of formats, with the format determined by a format string you give it
HTH,
Egge-Jan
RamB
Thank you, but my all workflow is in R. So Not sure what you mean ?
ShaunWalbridge
Can you provide a code sample? I'm not able to reproduce this, as.Date and POSIX date objects are being converted to a Date field in an output geodatabase in my tests. Here's an example:
library(arcgisbinding)
arc.check_product()
Sys.setenv(TZ="UTC")
df <- data.frame(
    a = c(0, 1, NA, -Inf, Inf),
    b = c("a", "b", NA, "c", ""),
    c = c(as.Date("2001-01-01"), NA, -99, 0, 1),
    d = c(as.POSIXct("2001-01-01"), NA, -99, 0, 1),
arc.write("date.gdb/with_date")
With that, I get two date columns, "c" and "d", which contain values I would expect.
andy_cdphe
I know this is an older thread but I just had to work through this issue. What worked for me was adding the posix at the very end, just before arc.write(). Something about converting the data.frame to a spatial object in R messed with the field types.
My process was:
1: existing data.frame()
2: coordinates()
3: set crs
4: posix field controls
5: arc.write()
