Oflline MAP "Fully disconnected "
614
06-05-2020 09:20 AM
MuhammadElfeki
my Desktop app contain a Map using Arcgis runtime SDK Tha App should work in a fully disconnected environment
(what i mean after i release the app and copy to another PC no way to be connected to the internet)
i done all the app on qt and the map provided via Arcgis-server using Map , MapGraphicsView Classes .
i found an example  LocalServerFeatureLayer but this also not working when i am disconnected only (map didn't show)  when connected (the map start working ).
so my question is  there is any way to get map of a country downloaded offline and installed into a local server on the same pc that contains the my app Even if I will pay for this , if this available what is the process to do that please.
Thanks a lot.
LucasDanzinger
Esri Frequent Contributor
The best way to work with fully offline data packages is to create a Mobile Map Package in ArcGIS Pro. Here is a tutorial on how to do this - Add layers to a map (offline) | ArcGIS for Developers
