Load Secure webmap
2158
12-16-2019 08:15 AM
LaurynasGedminas2
What is the proper way to load secure webmap?
so far this code does not work:
MapView {
   anchors.fill: parent
   Credential{
      username: user
      password: password
   Map {
   initUrl: webmap_secure
Tags (4)
LucasDanzinger
Esri Frequent Contributor
Laurynas-
Because a Map can contain layers and tables that are also secured, you can't directly set a credential on the Map. Instead, you need to use our AuthenticationManager, which is a class that catches all security challenges and notifies the developer, allowing the developer to satisfy the challenge (pass in a credential to the request). This is discussed further here - Access the ArcGIS platform—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
Example code would be:
ApplicationWindow {
    width: 800
    height: 600
    // add a mapView component
    MapView {
        // add a map to the mapview
        Map {
            initUrl: "securedWebmapUrl"
    Connections {
        target: AuthenticationManager // singleton instance
        onAuthenticationChallenge: {
            console.log("authentication challenge for", challenge.requestUrl)
            if (challenge.authenticationChallengeType === Enums.AuthenticationChallengeTypeUsernamePassword) {
                var credential = ArcGISRuntimeEnvironment.createObject("Credential", {
        username: "username",
        password: "password"
                challenge.continueWithCredential(credential);
If you wanted to instead show a user a dialog to sign in, you could use our Toolkit component called AuthenticationView:
import QtQuick 2.6
import QtQuick.Controls 2.2
import QtPositioning 5.12
import Esri.ArcGISRuntime 100.6
import Esri.ArcGISRuntime.Toolkit.Dialogs 100.6
ApplicationWindow {
    width: 800
    height: 600
    MapView {
        Map {
            initUrl: "secureWebmapUrl"
    AuthenticationView {
        authenticationManager: AuthenticationManager
LaurynasGedminas2
Thank you for quick response,
could be it be:
                                   "token": token
its not working right now.
Laurynas
LucasDanzinger
I believe if you want to directly set the token string, you may need to also set the referer property - Credential QML Type | ArcGIS for Developers .
Are you re-generating tokens somewhere else in your app? If you provide username and password instead, the credentials will be stored in the CredentialCache, and expired tokens will be automatically handled in the API. With your workflow, if your token expires, you'll need to handle fetching a new token and providing it to the Runtime API
LaurynasGedminas2
Modifying the AppStudio "Quick Report" App, they are storing the token as string. the token works properly if i add single feature layer with:
Credential{
                token: app.settings.value("token", "")
            FeatureLayer {
                            // feature table
                            ServiceFeatureTable {
                                url: app.featureLayerURL
                                credential: creds
LaurynasGedminas2
So, The code works if i use the username and the password from the Quick Report Template App, it does not work if i use token from the App:
Connections {
                    console.log("LG-authentication challenge for", challenge.requestUrl)
                    var user = rot13(app.settings.value("username",""))
                    var password = rot13(app.settings.value("password",""));
                    var token = app.settings.value("token","");
                        /*var credential = ArcGISRuntimeEnvironment.createObject("Credential", {
        username: user,
        password: password
                        console.log(token);
        "token": token
                        //credential.token = app.token
AppStudio for ArcGIS
