kml layers that use web style icons in a disconnected system
1387
11-30-2022 04:51 AM
TroyFoster
So a coworker gave me a kml file to display in my disconnected system and that kml file refers to symbols from web icons.
So I modified the sample from https://github.com/Esri/arcgis-runtime-samples-qt/tree/main/ArcGISRuntimeSDKQt_CppSamples/Layers/Dis... and put the kml as the local file to load.
In my disconnected system the icon does not end up being correct, just a red X.  I know that the symbols used will be fairly limited and I should be able to pre-cache them somewhere in my system.
Is there a way to have some sort of configuration mapping saying that if it is looking for a certain weburl to actually load a certain local file?
This is on Runtime Qt 100.14,
sample picture:
simplified kml snippet:
<?xml version="1.0" encoding="UTF-8"?>
<kml xmlns="http://www.opengis.net/kml/2.2" xmlns:atom="http://www.w3.org/2005/Atom" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2">
  <Document>
    <name>foo</name>
    <Folder>
      <name>foo Points</name>
      <Style id="fooPoint">
        <IconStyle>
          <scale>0.5</scale>
          <Icon>
            <href>https://maps.gstatic.com/intl/en_us/mapfiles/markers2/measle_blue.png</href>
          </Icon>
          <hotspot x=".5" xunits="fraction" y=".5" yunits="fraction"/>
        </IconStyle>
      </Style>
      <Placemark>
        <name>Foo</name>
        <description><![CDATA[<h1>Hello Esri!</h1>]]></description>
        <TimeStamp>
          <when>1980-01-01T00:01:01Z</when>
        </TimeStamp>
        <styleUrl>#fooPoint</styleUrl>
        <Point>
          <coordinates>-70.000000,30.0000000,0.00000000</coordinates>
          <altitudeMode>absolute</altitudeMode>
        </Point>
      </Placemark>
    </Folder>
  </Document>
</kml>
JamesBallard1
Hi @TroyFoster. First, sorry for the delay in getting back to you. We've been busy preparing our first Qt 6 release, which is coming very soon.
I looked at your code and situation, and I don't know if there is any way to map those online urls to a local cache. However, I did find that with 100.14 I was able to load them up on my mac with local paths once I downloaded the files.
See below.
Let me know if that works for you.
TroyFoster
Adding more onto this, when I traverse the kml nodes, the "foo Points" folder node, its style ends up being a nullptr when the kml is loaded.  When I traverse to the placemark node I can see that for the placemark the style is iconStyle but changing the url for the icon does not seem to affect the drawing of the symbol.
JamesBallard1
See below.
TroyFoster
I think that is what I am going to end up doing, have the icon png files downloaded local and have a sed script do a search and replace of the web addresses with local paths, then have the map load in the modified kml file.
