Installation Error For Mac (LAX)
8934
12
04-02-2015 11:56 PM
CeyhunYilmaz
Hi , I am trying to install Arcgis Runtime SDK for Qt on Mac OS(10.10). when i run RuntimeSDKQt_Installer which in ArcGIS RuntimeSDK Qt 10.2.5.dmg file on the mac terminal i got an error  as below :
/Volumes/ArcGIS\ RuntimeSDK\ Qt\ 10.2.5/RuntimeSDKQt_Installer.app/Contents/MacOS/RuntimeSDKQt_Installer ; exit;
Admin-MacBook:~ admin$ /Volumes/ArcGIS\ RuntimeSDK\ Qt\ 10.2.5/RuntimeSDKQt_Installer.app/Contents/MacOS/RuntimeSDKQt_Installer ; exit;
Archive:  /Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources/Java/uninstall.zip
  inflating: Change ArcGISRuntimeSDKQt Installation.app/Contents/PkgInfo
  inflating: Change ArcGISRuntimeSDKQt Installation.app/Contents/Info.plist
  inflating: Change ArcGISRuntimeSDKQt Installation.app/Contents/Resources/LaunchAnywhere.icns
  inflating: Change ArcGISRuntimeSDKQt Installation.app/Contents/Resources/Java/libsecuretextservices.dylib
  inflating: Change ArcGISRuntimeSDKQt Installation.app/Contents/Resources/Java/IAMac.dylib
  inflating: Change ArcGISRuntimeSDKQt Installation.app/Contents/MacOS/Change ArcGISRuntimeSDKQt Installation
  inflating: Change ArcGISRuntimeSDKQt Installation.app/Contents/Resources/Java/linking.zip
------Executable: "/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java" -Xms16m -Xmx192m -cp "/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources/Java/Execute.zip:/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources/Java/IAClasses.zip:/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources/Java/installscript.zip:/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources/Java:/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources/Java/linking.zip" -Dfile.encoding=UTF-8 -Djava.library.path=.:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java:"/Volumes/ArcGIS RuntimeSDK Qt 10.2.5":"/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib":"/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources/Java":"/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/MacOS":"/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources" -Xdock:name="ArcGISRuntimeSDKQt" -Xdock:icon="/Volumes/ArcGIS RuntimeSDK Qt 10.2.5/RuntimeSDKQt_Installer.app/Contents/Resources/SelfExtractor.icns" com.zerog.lax.LAX "/var/folders/vv/rzddmcdd6xq894qqkr277xm40000gn/T/app.properties"-------
Trying to load library IAMac
IAMac utility library loaded
The properties files is missing an essential property: lax.main.class. Please make sure it exists in the properties file: /var/folders/vv/rzddmcdd6xq894qqkr277xm40000gn/T/app.properties
Unable to Launch Java Application: The properties files is missing an essential property: lax.main.class. Please make sure it exists in the properties file: /var/folders/vv/rzddmcdd6xq894qqkr277xm40000gn/T/app.properties
Unable to locate the application's 'main' class. The class 'null' must be public and have a 'public static void null(String[])' method. (LAX)
Unable to Launch Java Application: Unable to locate the application's 'main' class. The class 'null' must be public and have a 'public static void null(String[])' method. (LAX)
logout
Anyone Help ?
CeyhunYilmaz
Hi Yue,
Yes this problem has blocked our works for Mac OS\IOS enviroment and unfortunately this hasn't solved.
I have been in touch Esri Support also since wrote here but they couldn't help me. Esri support recommend to install 10.2.6 version . But results happened same direction (10.2.5)  . What I intend to say is I cannot install Arcgis Sdk For Qt on Mac OS and i have no belief to will happen
Thanks (Sorry my bad english )
YueWu1
by Esri Regular Contributor
Hi Ceyhun,
I think the issue is related to mac OSX language, once change the Operation System language to English the issue will resolve.
UPDATE:
Here is the bug info just in case you need to track.
[BUG-000090287 ArcGIS Runtime SDK for QT 10.2.6 unable to install when using Turkish as default language on Mac OSX]
CeyhunYilmaz
Hi Yue,
I solved problem and tell it to Jino Contreras​ via message before you replied me. Problem's why is the language.
Thanks.
Ceyhun
