ImageTiledLayer in QML crashes on 100.8 and 100.9
883
12-28-2020 08:47 AM
JustinSteventon
Hi there,
I would like to have a blank base map for cases where I am offline, but users still want to see the points they have captured relative to one another.
To do this, I use the following (which works on 100.7 and below), but it crashes. What am I doing wrong?
Thanks!
import QtQuick 2.6
import QtQuick.Controls 2.2
import Esri.ArcGISRuntime 100.9 as Esri
ApplicationWindow {
    width: 800
    height: 600
    title: "ImageTiledLayer bug"
    Esri.MapView {
        anchors.fill: parent
        focus: true
        Esri.Map {
            Esri.ImageTiledLayer {
                fullExtent: Esri.Envelope { xMin: -20037508.34; yMin: -20037508.34; xMax: +20037508.34; yMax: +20037508.34; spatialReference: Esri.SpatialReference { wkid: 3857 } }
                noDataTileBehavior: Esri.Enums.NoDataTileBehaviorBlank
                tileInfo: Esri.TileInfo {
                    origin: Esri.Point { x: -20037508.34; y: +20037508.34; spatialReference: Esri.SpatialReference { wkid: 3857 } }
                    dpi: 96; tileWidth: 256; tileHeight: 256; spatialReference: Esri.SpatialReference { wkid: 3857 }
                    levelsOfDetail: [
                        Esri.LevelOfDetail {level: 0; resolution: 156543.03390624999884; scale: 591657527.50934994221}
                        , Esri.LevelOfDetail {level: 1; resolution: 78271.516953124999418; scale: 295828763.7546749711}
                        , Esri.LevelOfDetail {level: 2; resolution: 39135.758476562499709; scale: 147914381.87733748555}
                        , Esri.LevelOfDetail {level: 3; resolution: 19567.879238281249854; scale: 73957190.938668742776}
                        , Esri.LevelOfDetail {level: 4; resolution: 9783.9396191406249272; scale: 36978595.469334371388}
                        , Esri.LevelOfDetail {level: 5; resolution: 4891.9698095703124636; scale: 18489297.734667185694}
                        , Esri.LevelOfDetail {level: 6; resolution: 2445.9849047851562318; scale: 9244648.867333592847}
                        , Esri.LevelOfDetail {level: 7; resolution: 1222.9924523925781159; scale: 4622324.4336667964235}
                        , Esri.LevelOfDetail {level: 8; resolution: 611.49622619628905795; scale: 2311162.2168333982117}
                        , Esri.LevelOfDetail {level: 9; resolution: 305.74811309814452898; scale: 1155581.1084166991059}
                        , Esri.LevelOfDetail {level: 10; resolution: 152.87405654907226449; scale: 577790.55420834955294}
                        , Esri.LevelOfDetail {level: 11; resolution: 76.437028274536132244; scale: 288895.27710417477647}
                        , Esri.LevelOfDetail {level: 12; resolution: 38.218514137268066122; scale: 144447.63855208738823}
                        , Esri.LevelOfDetail {level: 13; resolution: 19.109257068634033061; scale: 72223.819276043694117}
                        , Esri.LevelOfDetail {level: 14; resolution: 9.5546285343170165305; scale: 36111.909638021847059}
                        , Esri.LevelOfDetail {level: 15; resolution: 4.7773142671585082653; scale: 18055.954819010923529}
                        , Esri.LevelOfDetail {level: 16; resolution: 2.3886571335792541326; scale: 9027.9774095054617646}
                        , Esri.LevelOfDetail {level: 17; resolution: 1.1943285667896270663; scale: 4513.9887047527308823}
                        , Esri.LevelOfDetail {level: 18; resolution: 0.59716428339481353316; scale: 2256.9943523763654412}
                        , Esri.LevelOfDetail {level: 19; resolution: 0.29858214169740676658; scale: 1128.4971761881827206}
                        , Esri.LevelOfDetail {level: 20; resolution: 0.14929107084870338329; scale: 564.24858809409136029}
                        , Esri.LevelOfDetail {level: 21; resolution: 0.074645535424351691645; scale: 282.12429404704568014}
                        , Esri.LevelOfDetail {level: 22; resolution: 0.037322767712175845822; scale: 141.06214702352284007}
                        , Esri.LevelOfDetail {level: 23; resolution: 0.018661383856087922911; scale: 70.531073511761420036}
                        , Esri.LevelOfDetail {level: 24; resolution: 0.0093306919280439614556; scale: 35.265536755880710018}
                tileCallback: function(level, row, column) {
                    return ""
LucasDanzinger
Esri Frequent Contributor
Thanks for reporting this. We've identified where this is going wrong. The crux of the problem is with the initialization order, where TileInfo assumes origin point is valid before it is. Here is some workaround code that works (although it is pretty ugly...)
import QtQuick 2.6
ApplicationWindow {
    width: 800
    height: 600
    function createOrigin() {
        return Esri.ArcGISRuntimeEnvironment.createObject("Point", { x: -20037508.34, y: +20037508.34, spatialReference: webMercator });
        wkid: 3857
    function createLods() {
        let lods = [];
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 0, resolution: 156543.03390624999884,     scale: 591657527.50934994221}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 1,  resolution: 78271.516953124999418,    scale: 295828763.7546749711} ));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 2,  resolution: 39135.758476562499709,    scale: 147914381.87733748555}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 3,  resolution: 19567.879238281249854,    scale: 73957190.938668742776}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 4,  resolution: 9783.9396191406249272,    scale: 36978595.469334371388}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 5,  resolution: 4891.9698095703124636,    scale: 18489297.734667185694}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 6,  resolution: 2445.9849047851562318,    scale: 9244648.867333592847} ));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 7,  resolution: 1222.9924523925781159,    scale: 4622324.4336667964235}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 8,  resolution: 611.49622619628905795,    scale: 2311162.2168333982117}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 9,  resolution: 305.74811309814452898,    scale: 1155581.1084166991059}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 10, resolution: 152.87405654907226449,    scale: 577790.55420834955294}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 11, resolution: 76.437028274536132244,    scale: 288895.27710417477647}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 12, resolution: 38.218514137268066122,    scale: 144447.63855208738823}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 13, resolution: 19.109257068634033061,    scale: 72223.819276043694117}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 14, resolution: 9.5546285343170165305,    scale: 36111.909638021847059}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 15, resolution: 4.7773142671585082653,    scale: 18055.954819010923529}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 16, resolution: 2.3886571335792541326,    scale: 9027.9774095054617646}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 17, resolution: 1.1943285667896270663,    scale: 4513.9887047527308823}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 18, resolution: 0.59716428339481353316,   scale: 2256.9943523763654412}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 19, resolution: 0.29858214169740676658,   scale: 1128.4971761881827206}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 20, resolution: 0.14929107084870338329,   scale: 564.24858809409136029}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 21, resolution: 0.074645535424351691645,  scale: 282.12429404704568014}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 22, resolution: 0.037322767712175845822,  scale: 141.06214702352284007}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 23, resolution: 0.018661383856087922911,  scale: 70.531073511761420036}));
        lods.push(Esri.ArcGISRuntimeEnvironment.createObject("LevelOfDetail", {level: 24, resolution: 0.0093306919280439614556, scale: 35.265536755880710018}));
        return lods;
    function createTileInfo() {
        return Esri.ArcGISRuntimeEnvironment.createObject("TileInfo",
                                                             origin: createOrigin(),
                                                             dpi: 96,
                                                             tileWidth: 256,
                                                             tileHeight: 256,
                                                             spatialReference: webMercator,
                                                             levelsOfDetail: createLods()
    Esri.MapView {
        focus: true
        Esri.Map {
                tileInfo: createTileInfo()
                    return ""
LucasDanzinger
import QtQuick 2.6
ApplicationWindow {
    width: 800
    height: 600
        wkid: 3857
        let lods = [];
        return lods;
                                                             dpi: 96,
                                                             tileWidth: 256,
                                                             tileHeight: 256,
    Esri.MapView {
        focus: true
        Esri.Map {
                    return ""
JustinSteventon
Thanks for the fast response, Lucas! My workaround involved a local web server, which is a whole other kind of clunky. I will look out for a permanent fix in an upcoming version.
