How to manage distance between symbols and labels on zoom in and zoom out in arcgis 100.6?
1151
09-14-2020 01:54 AM
AbhijeetSatam
I am using arcgis 100.6 and qt 5.12.1 for application development.
I want to display some text information alongside my symbol(S1) . I have tried 2 methods to do the same and facing issues in both.
1. Using TextSymbol class
2. Using labelDefinitions() function of  LabelDefinitionListModel class
1.  Using TextSymbol classWhen using TextSymbol to display the data, I first assigned same coordinates as the symbol(S1) to the textSymbol (TS) . Both the symbols overlap as expected
To avoid the overlap I set the geometry of the TextSymbol with some offset as follows:
TS->setGeometry(Point(S1.y + 0.01, S1.x + 0.01, 4326));
However I am observing that the distance between both symbols changes when zoomed in or out. Below are images for S1 and TS with same offset (0.01) but different zoom in scales. The distance between S1 and TS increases as I zoom in more. Is there a way to avoid this??
2. Using labelDefinitions() function of  LabelDefinitionListModel class: The second way I used was using labelDefinitions(). Here the distance between the symbol (S1) and label (L1) remains constant on zoom in zoom out but the placement of  L1 is far from the S1. I tried different labelPlacement options available in labelDefinitions() but all seem to display approximately the same distance.
The labeldefinitions() uses the following json string:
QString mapcode::createLabelJsonName() const
  return QString(QStringLiteral("{\"labelExpressionInfo\":{\"expression\":\"'I - ' + $feature.NAME\"},"
                                "\"labelPlacement\":\"esriServerPointBelowCenter\","
                                "\"where\":\"NAME <> ' '\","
                                "\"allowOverlapOflabel\":\"avoid\","
                                "\"allowOverlapOfFeatureBoundary\":\"avoid\","
                                "\"maxScale\":\"0\",\"minScale\":\"0\","
                                "\"symbol\": {\"angle\":0,\"backgroundColor\":[0,0,0,0],"
                                "\"borderLineColor\":[0,0,0,0],"
                                "\"borderLineSize\":0,\"color\":[0,0,255,255],"
                                "\"font\": {\"decoration\":\"none\",\"size\":10,"
                                "\"style\":\"normal\",\"weight\":\"normal\"},"
                                "\"haloColor\":[255,255,0,255],\"haloSize\":1.5,"
                                "\"horizontalAlignment\":\"center\",\"kerning\":false,"
                          "\"type\":\"esriTS\",\"verticalAlignment\":\"middle\",\"xoffset\":0,\"yoffset\":0}}"));
I want L1 to be placed directly above or below S1. Is there a way to acheive this using labels??
LucasDanzinger
Esri Frequent Contributor
For the first workflow, I think the problem is that as you zoom in, the added .01 will have a larger effect. The better solution would be to use the exact same geometry as the red symbol, but then adding X and Y offset to the TextSymbol - MarkerSymbol Class | ArcGIS for Developers
LucasDanzinger
