How to create offline TPK or VTPK maps? Need help
1872
11-18-2020 02:12 PM
ArmandoGarcia3
Hello friends of Esri,
I am fairly new to  ArcGIS and it's posisble I have the wrong services. I have been heavily searching all over the place to create some offline maps, for when I am in a scenario with no internet. I have no issue implementing and displaying an online basemap, or an offline tpk map (supplied from somewhere else).
My issue is that I am creating maps on the ArcGIS online, and I am saving them. I am then setting them for offline use, and then using the GenerateOfflineMap to save them.
The issue is:
1.) The download button doesn't even show once I successfully create a SMALL map.
2.) The TPK maps I am generating can only be so big, which are very very small, thus making them useless to me.
Do I need to ArcGIS for Desktop or ArcGIS pro to make a map, that I can then save and download as a tpk file?
I feel like this shouldn't be that complicated. Maybe I am approaching the situation the wrong way, but the README for generateofflinebasemap doesn't make much sense, imo.
Can anyone just tell me, what's the easiest way to create a map, let's say, the City of Huntsville, AL, or the general area. I don't even need any type of services where I need to add layers of things. I just need the map, so I can add my own objects and paste via lat/long for tracking, etc.
I'm sorry if I sound like a rookie, but I don't need ArcGIS for anything but an offline map, and I have been stuck for awhile.
Cheers,
Z
by Anonymous User
Not applicable
Hi @ArmandoGarcia3
Can you confirm that you have followed the steps mentioned in the documentation here: https://doc.arcgis.com/en/collector-classic/windows/create-maps/offline-map-prep.htm
Also, download button will only appear if all the conditions are met.
I'll suggest that you try to create an offline capable map with just a single layer. Get familiar with the process and the requirements. Then move to your production web map.
Regards
Vagish
