I'm trying to convert a grey scale image to RGB, but not able to do so over Qt SDK.
I was able to convert in ArcGIS pro as follows:
But samething I'm trying over qt code, I'm not able to do so color map rendering on raster file gives me below output, just single line.
does anyone faced similar issue and guide me. If required I can share code.
Virendra
Did you take a look at the Stretch Renderer samples?
C++ version - https://github.com/Esri/arcgis-runtime-samples-qt/tree/main/ArcGISRuntimeSDKQt_CppSamples/Layers/Ras...
QML version - https://github.com/Esri/arcgis-runtime-samples-qt/tree/main/ArcGISRuntimeSDKQt_QMLSamples/Layers/Ras...
Thanks Lucas for reply!
we have tried that but this is one part of of Grey to RGB, 2nd part to convert Stretch image (0-255) as per user defined colour pallet is not working. if you have any similar example please share it.
Virendra
Can you share some of your code for creating the renderer & layer?
Your code sample reads color values from a text file. What does your `QList<QColor> colors` end up containing?
Also, did you take a look at the ColormapRenderer sample? This assigns color values to each pixel value https://github.com/Esri/arcgis-runtime-samples-qt/blob/main/ArcGISRuntimeSDKQt_CppSamples/Layers/Ras...
