Filter GeoView by time instead of time span
1688
6
04-08-2021 12:10 PM
nikschm00
Hello Guys,
I want to filter the GeoView by time,not by a time span.
The only possibility i found, was setTimeExtent(). It dont work, to set the same StartDate and EndDate in Extent.
If i have a Feature(StartDate= 0:30; EndDate= 0:35), i want to show it, if I set the time to 0:33.
JamesBallard1
@nikschm00 I checked with my colleagues and this appears to be a bug. Thank you for reaching out with this. I have logged an internal bug so we can investigate my thoroughly and fix it.
JamesBallard1
Hi @nikschm00 ,
Your workflow sounds correct. Do you have any example code that demonstrates the problem? I'd like to troubleshoot a bit on our end to see if there's a bug.
nikschm00
I use a modified version of the TimeSliderController from ArcGIS Runtime Toolkit.
Code of Method that use setTimeExtentCode of Method that use setTimeExtent
I only can show the feature, if I set the Extent of the GeoView larger or same than the Extent of the Feature.
Enclosed is a picture of the dataset, I use.
If I use this method in connection with the enclosed table, nothing will be shown.
JamesBallard1
Thanks for the updated info @nikschm00. I will do some research and get back to you soon.
JamesBallard1
nikschm00
Okay, that sounds good, thanks for the fast reply.
JamesBallard1
@nikschm00 ,
  Thanks again for letting us know about this. We have fixed this problem in the upcoming 100.12 release, which will be out before the end of the year.
