Can't display map/Topographic.tpk
4245
03-28-2014 01:42 AM
Bryant_JamesLanuza1
hi all,
help, after i installed ArcGIS Runtime Qt Samples 10.2 in Windows 7 pro, unit processor Intel(R) Core(TM)2 Quad CPU,
then i'm trying to display Tiled Layer Viewer  but can't display. Please attached.
thanks and advanced.
JeanneTrieu
Can you let me know if you are able to view the map if you switch to another sample such as the Graphics Layers->Add Graphics?
Bryant_JamesLanuza1
hello Jen,
I'm trying to view other samples like Image Services Layers, Graphics Layers and etc. but can't display map. 😞
JeanneTrieu
Can you try updating your graphics card driver? This should fix the issue.
Regards,
BhushanShetty
Hello Bryant,
Did you find any solution to your problem... because even I am facing the same. There are no Debug Errors. Same sample code as give in ArcGIS Runtime SDK... An application window pops up however there is no basemap shown.
FYI: Graphic card used is GeForce 9200.
Regards,
Bhushan
