Blank black screen when I am giving just blank scene and passing to scene view
3186
9
07-19-2019 04:47 AM
GirishchandraY
Can you please check why black and when click white scte screen appearing when  I am expecting just blank Globe..for 3d view
Tags (3)
LucasDanzinger
Esri Frequent Contributor
Can you provide some more details? Which platforms are you on? What does your code look like? Are you on a VM? What graphics card and GPU do you have? Do map views work as expected?
GirishchandraY
I am Using Windows 10
Just a Simple code with blank scene and scene view same code is working on other machine.
I am not using any VM
Graphics Card is NVIDIA QUADRO 4000...DIRECTX 12
MapView is working as expected..
LucasDanzinger
can you please share your code and a screenshot of what it looks like?
Girishchandra_Yendargaye
Code has these lines...
 // Create a Blank scene
    Scene* scene = new Scene(this);
    // Create a scene view, and pass in the scene
    m_sceneView = new SceneGraphicsView(scene, this);
    // set the sceneView as the central widget
    setCentralWidget(m_sceneView);
LucasDanzinger
I tested this out on Windows but couldn't reproduce the issue. If this is a high priority issue, I suggest you contact Esri Support to troubleshoot further.
BrianJensen2
I am seeing this on the scene view demos as well
Intro to SceneView - Create a 3D map | ArcGIS API for JavaScript 4.12
however if you change the basemap it will show as expected
Scene Viewer
it doesn't happen in firefox or edge only chrome
I get a warning in the console that look suspicious
[.WebGL-0000027793BD2230] GL_INVALID_OPERATION: Error: 0x00000502, in ../../third_party/angle/src/libANGLE/renderer/d3d/d3d9/Image9.cpp, createSurface:278. Internal D3D9 error: HRESULT: 0x8876086C: Failed to create image surface
this could have something to do with chome's latest release
JosVroegop2
I have the same problem with the scene viewer in ArcGIS Online & Chrome. Is there a fix for this?
LucasDanzinger
I'm unclear what the issue being reported is. I believe the initial issue is referring to a Runtime SDK for Qt app whereas the reports from Brian and Jos are with the Scene Viewer app in the browser? If you are experiencing issues with the scene viewer in the browser, it would be best to report this to the ArcGIS Online space.
This issue is for Runtime SDK for Qt App only Lucas.
