Clip tool(annotation) while projection transformation
1895
03-15-2017 08:38 PM
sivaprakash
Hi
python snippets
arcgis map
clip_analysis tool is not working properly for Annotation layer provided the output in another projection system. Anyone else encountered this.
To recreate the issue:
Open python window
set outcoordinatesystem set to another.
Try out clip_analysis for annotation layer.
The output is not as expected. The annotation text is shown at different place.
Please find the following associated snippet
import arcgisscripting
gp = arcgisscripting.create()
gp.OutputCoordinateSystem = "4326" #different wkid
gp.clip_analysis("<<Input Annotation Layer>>","Export_Output","<<Output Annotation Layer>>")
output is not projected correctly as expected
Please help me out in this case. thanks for upcoming help.
Siva
DanPatterson_Retired
In order to clip, the geometries must overlap Clip Analysis in the Environment Setting section at the bottom, you will see that the tool honors the Extent parameter.  In any event, the result of a clip would contain the attributes of the layer being clipped, there is no mention of associated joined attributes being carried over since they are only associated with the output, not part of it, hence, geometry seems to be the focus
