Hello, I try to use Calculate Field to get the value for field “DESCRIPTION” from combine data of other fileds, as the image 1 attached.
However, my below first Syntax is not working
arcpy.CalculateField_management(UT_CROSSING, "DISCREPTION", "[COMPANY]+\" \"+ [LOCATION]+\" \"+ [TYPE]+\" \"+\" SIZE=\"+ [SIZE]", "VB", "")
If I use below syntax, there no space between each field data, show as in image 2 arcpy.CalculateField_management("UT_CROSSING","DISCREPTION","!COMPANY!" + " " + "!LOCATION!" + " " + "!TYPE!" + " " + "!SIZE!" ,"PYTHON")
It would be wonderful if you can tell me my mistake.
Thanks in advance!
