Write ArcPy cursor results to a text file in different folders with a different name based on cursor condition. Define function is not working.Multiprocessing
13537
41
06-02-2019 07:48 AM
BIJOYGAYEN
Middle section of the code, I separate the attribute value in a different category ("AAA","BBB","CCC") and every category have Ten land-use types, initially, I set Three land use type (LAND_10, LAND_20, LAND_30) for test code. Now I used the update cursor for different land-use type(LAND_10, LAND_20, LAND_30) , and saved the text file to there corresponding Land use folders(Like, Land_10 ....Land_30) under the "AAA" folder. similarly, this function I will use for categories "BBB","CCC" .
Initially, I write this code for category "AAA" but I want to use this function for category "BBB","CCC" by defining a function(uncheck all define function), but is not working. Below is my code please check it.
First of all, I want to reduce my code (Because I have 10 land type initially I write three) and the whole function I want to use as a defined function for a different category.
Another thing is Multiprocessing, Multithreading I want to use this function for the code because of initially my code takes much more time for one processes. In my case how to use the multiprocessing function.
please look at this matter and give me a suggestion to manipulate this code.
import datetime
start = datetime.datetime.now()
print 'start run: %s\n' % (start)
import arcpy ,os ,sys,csv,errno
from arcpy import env
from arcpy.sa import *
import datetime
import re
import glob
import itertools
import multiprocessing as mp
print("Number of processors: ", mp.cpu_count())
cellsize = "F:\\DB_test_data\\TEST_RAY\\TEST1\\MOD02HKM_A2017001_0530_NDVI_AA.img"
d1="F:\\DB_test_data\\VAR2\\cldmask\\tt"
CLDMASK = glob.glob(d1 + os.sep + "*.Aerosol_Cldmask_Land_Ocean-Aerosol_Cldmask_Land_Ocean.tif")
CLDMASK.sort()
if CLDMASK is None:
    print 'Could not open the CLDMASK raster files'
    sys.exit(1)
else:
    print 'The CLDMASK raster files was opened successfully'
#print CLDMASK
d2="F:\\DB_test_data\\TEST_RAY\\TEST1"
NDVI = glob.glob(d2 + os.sep + "*A2017001_0530_NDVI_AA.img")
NDVI.sort()
if NDVI is None:
    print 'Could not open the NDVI raster files'
    sys.exit(1)
else:
    print 'The NDVI raster files was opened successfully'
#print NDVI
d3="F:\\DB_test_data\\VAR2\\IDL\\MOD02HKM\\TEST"
BAND1 = glob.glob(d3 + os.sep + "*A2017001_0530_006_BAND_1.img")
BAND1.sort()
if BAND1 is None:
    print 'Could not open the BAND1 raster files'
    sys.exit(1)
else:
    print 'The BAND1 raster files was opened successfully'
#print BAND1
d4="F:\\DB_test_data\\VAR2\\IDL\\MOD02HKM\\TEST"
BAND2 = glob.glob(d4 + os.sep + "*A2017001_0530_006_BAND_2.img")
BAND2.sort()
if BAND2 is None:
    print 'Could not open the  BAND2 raster files'
    sys.exit(1)
else:
    print 'The BAND2 raster files was opened successfully'
#print BAND2
d4="F:\\DB_test_data\\VAR2\\IDL\\MOD09\\TEST"
BAND3 = glob.glob(d4 + os.sep + "*A2017001_0530_006_BAND_3.img")
BAND3.sort()
if BAND3 is None:
    print 'Could not open the BAND3 raster files'
    sys.exit(1)
else:
    print 'The BAND3 raster files was opened successfully'
#print BAND3
d5="F:\\DB_test_data\\VAR2\\IDL\\MOD02HKM\\TEST"
BAND4 = glob.glob(d5 + os.sep + "*A2017001_0530_006_BAND_4.img")
BAND4.sort()
if BAND4 is None:
    print 'Could not open the  BAND4 raster files'
    sys.exit(1)
else:
    print 'The BAND4 raster files was opened successfully'
#print BAND4
d6 = r"F:\\DB_test_data\\VAR2\\MOD04_l2"
AOD = glob.glob(d6 + os.sep + "*Corrected_Optical_Depth_Land_2-Corrected_Optical_Depth_Land.tif")
AOD.sort()
if AOD is None:
    print 'Could not open the AOD raster files'
    sys.exit(1)
else:
    print 'The AOD raster files was opened successfully'
Scale_factor = float(0.0010000000474974513)
add_offset = float(0.0)
Fill_value = float(-9999)
outdir="F:\\DB_test_data\\VAR4\\"
for a,b,c,d,e,f,g in zip (CLDMASK ,NDVI ,BAND1 ,BAND2 ,BAND3 ,BAND4,AOD):
    print ("processing:"+ a)
    arcpy.AddMessage("processing:{}".format(b.split('\\')[4][9:30]))
    name = c.split("\\")
    filename=name[6][9:33]
    print filename
    arcpy.AddMessage("processing:{}".format(d.split('\\')[6][9:33]))
    arcpy.AddMessage("processing:{}".format(e.split('\\')[6][9:30]))
    arcpy.AddMessage("processing:{}".format(f.split('\\')[6][9:33]))
    print ("processing:"+ g)
    setnull =arcpy.gp.SetNull_sa(g,g, "in_memory/dat", "\"Value\" = -9999")
    ras=arcpy.Raster(setnull)
    Data=(ras-add_offset)*Scale_factor
    da = Con((Data >= 0.0) & (Data <= 0.1),1)
    # Process: Extract by Cloud_Mask
    tempEnvironment0 = arcpy.env.cellSize
    arcpy.env.cellSize = "MAXOF"
    ndvi_msk=arcpy.gp.ExtractByMask_sa(b, a)
    Band1_mask=arcpy.gp.ExtractByMask_sa(c, a)
    Band2_mask=arcpy.gp.ExtractByMask_sa(d, a)
    Band3_mask=arcpy.gp.ExtractByMask_sa(e, a)
    Band4_mask=arcpy.gp.ExtractByMask_sa(f, a)
    arcpy.env.cellSize = tempEnvironment0
    # Process: Extract by Mask using AOD less than 0.1 value
    arcpy.env.cellSize = cellsize
    ndvi_msk1=arcpy.gp.ExtractByMask_sa(ndvi_msk, da)
    Band1_mask1=arcpy.gp.ExtractByMask_sa(Band1_mask, da)
    Band2_mask2=arcpy.gp.ExtractByMask_sa(Band2_mask, da)
    Band3_mask3=arcpy.gp.ExtractByMask_sa(Band2_mask, da)
    Band4_mask4=arcpy.gp.ExtractByMask_sa(Band2_mask, da)
    try:
        # Raster to point
        field ="VALUE"
        Point=arcpy.RasterToPoint_conversion(ndvi_msk1,"in_memory/fileroot",field)
        shape=arcpy.sa.ExtractMultiValuesToPoints(Point,[[ndvi_msk1,"NDVI"],[Band1_mask1,"Band1"],[Band2_mask2,"Band2"],
        [Band3_mask3 ,"Band3"],[Band4_mask4,"Band4"]], "NONE")
        #Add Two Fields Name and Name2
        [arcpy.AddField_management(shape,field_name, "TEXT", field_length = 50)
        for field_name in ["Name", "Name2"]]
        arcpy.AddMessage("Successfully Added NAME fields ")
        fieldss = ['Band1','Name']
        with arcpy.da.UpdateCursor(shape, fieldss) as cursor:
    			    for row in cursor:
    			        if (row[0] > 0.02 and row[0] < 0.06):
    			            row[1] = 'AAA'
    			            print ("processing1:""{0:.8f}, {1}".format(row[0], row[1]))
    			        elif (row[0] >= 0.06 and row[0] < 0.09):
    			            row[1] = 'BBB'
                          # print ("processing1:""{0:.8f}, {1}".format(row[0], row[1]))
    			        elif (row[0]  >= 0.09):
    			            row[1] = 'CCC'
    			        else:
    			            row[1] = 'NA'
    			        # Update the cursor with the updated list
    			        cursor.updateRow(row)
    	# Process: Select Layer By Attribute for separate the catagories "AAA","BBB,"CCC"
        arcpy.MakeFeatureLayer_management(shape,"lyr1")
        AAA = arcpy.SelectLayerByAttribute_management("lyr1", "NEW_SELECTION", "\"Name\" = 'AAA'")
        print "Successfully Process : Select Layer By Attribute for AAA "
        arcpy.MakeFeatureLayer_management(shape,"lyr2")
        BBB = arcpy.SelectLayerByAttribute_management("lyr2", "NEW_SELECTION", "\"Name\" = 'BBB'")
        print "Successfully Process : Select Layer By Attribute for BBB "
        arcpy.MakeFeatureLayer_management(shape,"lyr3")
        CCC = arcpy.SelectLayerByAttribute_management("lyr3", "NEW_SELECTION", "\"Name\" = 'CCC'")
        print "Successfully Process : Select Layer By Attribute for CCC "
      # Writing tables for categories("AAA","BBB,"CCC") and individual category have three Land type
      # that will be save in different folder and their individual name
      #------------------First we write category "AAA" and their indiviual land type--------------------------------------#
        category="AAA"
        file_name=filename
        base_path = r"F:\\DB_test_data\\VAR4\\"
      	 #def TableTotext(Input_Data,base_path,category,file_name):
      	     #def Land_10():
        land_use='LAND_10'
        outdir = os.path.join(base_path,category,land_use)
        if not os.path.exists(outdir):
      	     print('\nCreating new output directory!\n'+outdir+'\n')
      	     os.makedirs(outdir)
        else:
      	     print ("Directory already exists" )
        ras_name = os.path.join(outdir,("{0}_{1}{2}_{3}".format(category,file_name,land_use,".txt")))
        fields = ['NDVI', 'Band1', 'Band2','Band3','Name',"Name2"]
        with open(ras_name, 'wb') as txtfile:
  	      arcpy.AddMessage("fields Writing For landuse 10")
  	      txtfile.write("  {0}    {1}      {2}      {3}   {4}    {5}\n".format(fields[0],fields[1],fields[2],fields[3],fields[4],fields[5]))
  	      with arcpy.da.UpdateCursor(AAA, fields) as cursor:
  	         for row in cursor:
  	            if (row[0] > 0.10 and row[0] < 0.20):
  	             row[5] = 'landuse_10'
  	             print ("processing_A:""{0:.8f} {1:.8f} {2:.8f} {3:.8f} {4}  {5}".format(row[0],row[1],row[2], row[3],row[4],row[5]))
  	             txtfile.write("{0:.8f} {1:.8f} {2:.8f} {3:.8f} {4}  {5}\n".format(row[0],row[1],row[2], row[3],row[4],row[5]))
  	         txtfile.close()
  	         print ("Successfully save the landuse 10 " )
  	                #return Land_10
  	     #def Land_20():
        land_use='LAND_20'
             os.makedirs(outdir)
        else:
  	          arcpy.AddMessage("fields Writing For landuse 20")
  	             for row in cursor:
  	                if (row[0] >= 0.20 and row[0] < 0.50):
  	                    row[5] = 'landuse_20'
  	                    print ("processing_B:""{0:.8f} {1:.8f} {2:.8f} {3:.8f} {4}   {5}".format(row[0],row[1],row[2], row[3],row[4],row[5]))
  	             txtfile.close()
  	             print ("Successfully save the landuse 20 " )
  	            #return Land_20
  	     #def Land_30():
        land_use='LAND_30'
             os.makedirs(outdir)
        else:
  	          arcpy.AddMessage("fields Writing For landuse 30")
  	             for row in cursor:
  	                if (row[0] >= 0.50):
  	                    row[5] = 'landuse_30'
  	                    print ("processing_C:""{0:.8f} {1:.8f} {2:.8f} {3:.8f} {4}  {5}".format(row[0],row[1],row[2], row[3],row[4],row[5]))
  	             txtfile.close()
  	             print ("Successfully save the landuse 30 " )
                  #return LAND_30
#------------------Second we write category "BBB" and their indiviual land type--------------------------------------#
        print "Code is OK"
    except:
     print "Error in Code"
print arcpy.GetMessages()
print 'finished run: %s\n\n' % (datetime.datetime.now() - start)
BIJOYGAYEN
Thank you sir...
BIJOYGAYEN
What is your final suggestion for my code? Please, sir, refer me any who can resolve this matter.
JoeBorgione
I'm pretty much tapped out for suggestions: my approach would be to modularize the code so  it's easier to follow the logic as well as capture any errors encountered along the way.
BIJOYGAYEN
How do I configure my code with multiprocessing and multithreading?
BIJOYGAYEN
Why the developer not focusing on my problem?
BIJOYGAYEN
 Base on my previous code I am trying to used multiprocessing function but is not working. please check this issue and give me a suggestion to resolve this issue.  Joshua Bixby Xander BakkerDan Patterson
if __name__ == "__main__":
        category="AAA"
        file_name="MOD022"
        try:
            t1=time.time()
            main(base_path,category,file_name,AAA)
            print "serial processing took:",time.time()-t1
            print "serial processing is OK"
        except Exception as e:
            print "Error in serial processing"
            print(err)
        try:
            t2=time.time()
            pool = multiprocessing.Pool(processes=4)
            A=pool.map(main,(base_path,"AAA",file_name,AAA))
            B=pool.map(main,(base_path,"BBB",file_name,BBB))
            C=pool.map(main,(base_path,"CCC",file_name,CCC))
            A.close()
            B.close()
            C.close()
            A.join()
            B.join()
            C.join()
            print "Pool took",time.time()-t2
            print "multiprocessing is OK"
            print "Error in multiprocessing "
            #print(err)
DanPatterson_Retired
Skip multiprocessing for now and show what the inputs and outputs are supposed to look like.  I am still seeing streams of code without knowing what the process is intending to do.  I don't even know if multi or parallel processing is the route to go.  There is a false assumption that this makes things better when indeed it is not necessarily the case.
BIJOYGAYEN
This code working FlowchartThis is path systemOutput text_file
Here I attach my working flow and folder destination system and output files. I think you will understand what I want to do.
import datetime
import datetime
import re
import glob
import itertools
print("Number of processors: ", multiprocessing.cpu_count())
CLDMASK.sort()
if CLDMASK is None:
    sys.exit(1)
else:
#print CLDMASK
NDVI.sort()
if NDVI is None:
    sys.exit(1)
else:
#print NDVI
BAND1.sort()
if BAND1 is None:
    sys.exit(1)
else:
#print BAND1
BAND2.sort()
if BAND2 is None:
    sys.exit(1)
else:
#print BAND2
BAND3.sort()
if BAND3 is None:
    sys.exit(1)
else:
#print BAND3
BAND4.sort()
if BAND4 is None:
    sys.exit(1)
else:
#print BAND4
AOD.sort()
if AOD is None:
    sys.exit(1)
else:
    print filename
    try:
        # Raster to point
        field ="VALUE"
    			    for row in cursor:
    			            row[1] = 'AAA'
    			            row[1] = 'BBB'
    			            row[1] = 'CCC'
    			        else:
    			            row[1] = 'NA'
        def geoprocess1(base_path,category,file_name,file):
            try:
             land_use='LAND_10'
                try:
                 os.makedirs(outdir)
                except OSError:
                  print ("Creation of the directory failed" )
                else:
                 print ("Successfully created the directory" )
             fields = ['grid_code', 'Band1', 'Band2','Band3','Name',"Name2"]
                  with arcpy.da.UpdateCursor(file, fields) as cursor:
                     for row in cursor:
                         txtfile.write(" {0:.8f} {1:.8f} {2:.8f} {3:.8f} {4}  {5}\n".format(row[0],row[1],row[2], row[3],row[4],row[5]))
                     txtfile.close()
             print('Sucess: geoprocess1 complete!')
            except Exception as err:
              print('Error: unable to complete geoprocess1')
              print(err)
        def geoprocess2(base_path,category,file_name,file):
            try:
             land_use='LAND_20'
                   try:
                     os.makedirs(outdir)
                   except OSError:
                   else:
                         for row in cursor:
                         txtfile.close()
             print('Sucess: geoprocess2 complete!')
              print('Error: unable to complete geoprocess2')
              print(err)
        def geoprocess3(base_path,category,file_name,file):
          try:
             land_use='LAND_30'
                   try:
                     os.makedirs(outdir)
                   except OSError:
                   else:
                         for row in cursor:
                         txtfile.close()
             print('Sucess: geoprocess3 complete!')
              print('Error: unable to complete geoprocess3')
              print(err)
        def main(base_path,category,file_name,file):
        #category="AAA"
        file_name=filename
        #category="AAA"
        file_name="MOD022"
        try:
            t1=time.time()
            main(base_path,"AAA",file_name,AAA)
            main(base_path,"BBB",file_name,BBB)
            main(base_path,"CCC",file_name,CCC)
            print(err)
        try:
            t2=time.time()
            A.close()
            B.close()
            C.close()
            A.join()
            B.join()
            C.join()
            #print(err)
Again... does it work for 1 set and what is the output? Does the above error out?  Does it produce anything or does it fail?
BIJOYGAYEN
First of all, the code does not show any error But when I include the multiprocessing function is not working. In every category ("AAA","BBB","CCC") have Ten landuse_type initially I write three types (geoprocess1 to 3) it needs to write more seven processes then the code will be bigger that's why I need to reduce this code. I previously uploaded my folder structure of one category( "AAA") and their output text file. Dan Patterson
