arcpy.AddField_management(inMemoryIntersect, "Traffic", "DOUBLE")
arcpy.AddMessage(str([field.name for field in arcpy.ListFields(inMemInt)]))
outstring = pprint.pformat([field.name for field in arcpy.ListFields(inMemInt)]) arcpy.AddMessage(outstring)
'"AGADT2005" * "Shape_Length"'
import arcpy from arcpy import env env.workspace = r"C:\temp\python\test.gdb" fc = "Parcels" arcpy.MakeFeatureLayer_management(fc, "IN_MEMORY\test") arcpy.AddField_management("IN_MEMORY\test", "PIN", "DOUBLE") lstFields = arcpy.ListFields("IN_MEMORY\test") for field in lstFields: print field.name
import csv, sys import arcpy as gp from arcpy import env env.workspace = r"C:\\Users\\thob\\Projects\\Road_Length.gdb" env.overwriteOutput = True BSMB = gp.MakeFeatureLayer_management("\\BSMB\\pntBSMB", "BSMB") ROADS = gp.MakeFeatureLayer_management("\\Background\\Local_network", "ROADS") inMemBuf = "in_memory/Buffer" inMemInt = "in_memory/Intersect" inMemSum = "in_memory/Statistic" print("All variables in memory") lstCalcD = [] distance = "500 Meters" rowsCohort = gp.SearchCursor(BSMB) for Brow in rowsCohort: BpntID = int(Brow.getValue("OldID")) print(BpntID) strSearch = "\"OldID\" = %s" %str(BpntID) BpntX = Brow.getValue("POINT_X") print BpntX BpntY = Brow.getValue("POINT_Y") gp.SelectLayerByAttribute_management(BSMB, "NEW_SELECTION", strSearch) gp.Buffer_analysis(BSMB, inMemBuf, distance) inF = [inMemBuf, ROADS] gp.Intersect_analysis(inF, inMemInt) gp.ListFields(inMemInt) gp.CalculateField_management(inMemInt, "Traffic", "[AGADT2005] * [Shape_Length]", "VB", "") statF = [["Traffic", "SUM"]] gp.Statistics_analysis(inMemInt, inMemSum, statF, "ID") lstB = [BpntID, BpntX, BpntY, inMemSum] print(lstB) lstCalcD.append(lstB) csvfile = open(r"C:\\User\\thob\\Projects\\lstTraf_x_d.csv", 'wb') csvFile = csv.writer(csvfile, dialect='excel', delimiter=',') csvFile.writerow(['ID,X,Y,Traffic_Load']) csvFile.writerows(lstCalcD) csvfile.close() gp.Delete_management("in_memory")
calcExpression = "'" + siteName + "'" arcpy.CalculateField_management(singleSurveyImageLocationsDD_FCIM,"SiteName",calcExpression,"PYTHON_9.3","#")
arcpy.AddMessage(str(arcpy.ListFields(inMemInt)))
!AGADT2005! * !Shape_Length!
unfortunately the result of always comes as "<Field object at 0x55c7f90[0x577c590]>" and I never get the field name.
One thing that may be tripping you up is if you go through shapefile format at some point in your processing, Shape_Length is more than 10 characters, so it can get truncated to SHAPE_LENG.
Signed in members can post, follow updates, and more. New here? Register a free account.
