What is the python expression for the second, third, fourth etc etc vertex along a line feature?
1659
08-13-2019 06:22 AM
deleted-user-iYZsZYnVovgT
What is the python expression for the second, third, fourth etc etc vertex along a line feature? !shape.firstpoint¡ is the first vertex and !shape.lastpoint¡ is the last vertex, but what's the expression for other vertices down the line?
LukeWebb
Theres no specific way to do this, this is likely a design decision, as features can have theoretically unlimited vertexes so loading all this info to populate a dictionary etc, could be expensive and have potential to massively slow down cursors.
Check out this article, that tells you the exact same thing I could but using many more words and much more coherently:
Reading geometries—ArcPy Get Started | ArcGIS Desktop
The code at the bottom should allow you to do as you require.
import arcpy
infc = arcpy.GetParameterAsText(0)
# Enter for loop for each feature
for row in arcpy.da.SearchCursor(infc, ["OID@", "SHAPE@"]):
    # Print the current multipoint's ID
    print("Feature {}:".format(row[0]))
    partnum = 0
    # Step through each part of the feature
    for part in row[1]:
        # Print the part number
        print("Part {}:".format(partnum))
        # Step through each vertex in the feature
        for pnt in part:
            if pnt:
                # Print x,y coordinates of current point
                print("{}, {}".format(pnt.X, pnt.Y))
            else:
                # If pnt is None, this represents an interior ring
                print("Interior Ring:")
        partnum += 1p
JoshuaBixby
MVP Esteemed Contributor
I agree with Luke that cursors are best when working with more in-depth properties or methods of geometries.  If you must work with the Field Calculator, the "Code samples -- geometry" section of Calculate Field examples—Help | ArcGIS Desktop shows how you would retrieve the geometry and then process it in a code block.
