Using two workspaces in one script?
1848
10-20-2022 03:24 AM
Sam_Poxon
Hello!
I've downloaded a large number of MODIS (MOD08_E3) raster files. I am looking to export them to a geodatabase, rename them, build an attribute table, add a field and then calculate that new field. I've attached screenshots of my code in it's current form.
I have two scripts as I am working from two different workspaces - one where the files are originally held and then the second workspace is the gdb where I want to do further processing. I'm new to python/coding - would it be possible to obtain some advice on how to combine the two into one script please?
Thank you!
JoshuaBixby
MVP Esteemed Contributor
Posting pictures of code isn't much better than giving someone a picture of money, i.e., you aren't going to get much of anything for it.  See Posting code with Syntax Highlighting on GeoNet  and Code Formatting... the basics++ .  Also, elaborate a bit more on what specifically isn't working.  If you are getting errors, share the specific error and tracebacks.
JoshuaBixby
Sam_Poxon
Hi, thanks for the info - will resubmit
