Updating the table source of an ArcGIS table frame layout element
2327
07-18-2022 01:36 PM
BrentLanford
Hello all,
Is there a way to re-connect the data source for an ArcGIS Pro table frame using Python code? The script I am using deletes the connection and I would like to re-establish that connection (later in the script) so that my layout (see below) displays my table statistics.
I'm a novice at Python programming. Any suggestions would be helpful.
by Anonymous User
Not applicable
I haven't done a table frame before, but looking at the arcpy.mp module and Table class, there is an updateConnectionProperties method that looks promising. Maybe you can just update connections instead of deleting (and breaking) them?
table-class
by Anonymous User
Not applicable
table-class
BrentLanford
Thanks. I think this is the solution to my problem!
VíctorAE
I have the same problem, I can't set a table frame's source to a new table generated from scratch using a python script. Is it possible?
GregNicholsICF
Answering the original post (sort of):    One way without python to get the table frame to update is to just close Pro and reopen Pro and reopen your layout and the table frame will update to reflect the current table values.
