Update Field Values
3139
9
03-20-2024 08:36 AM
kapalczynski
I have a question...I am trying to update a specific field with the code below. I want to query all the data and change a field named "FLAGFIELD" to YES
I can get at the Portal ID for the Service and point to the correct table and set the proper JSON payload...
But I am missing where I am querying or selecting with a where clause of 1=1
Can anyone help with this part?  How do I "Change ALL records to YES in the field FLAGFIELD"
Thanks
    gis = GIS("https://xxxxxxx", "xxxxxx", "xxxxxxxx")
    #currenttoken = gis._con.token
    portal_item = gis.content.get('b373b127exxxxxxxxxx0dfb14a1')
    ports_layer = portal_item.tables[0]
    # We need to reconstruct json features to be updated
    FLAGFIELDvalue = 'YES'
    # construct json
    add_data = {
          "attributes" : {
            "FLAGFIELD" : FLAGFIELDvalue,
    # Push updates
    add_updates = ports_layer.edit_features(updates = [add_data])
JakeSkinner
Esri Esteemed Contributor
Hi @kapalczynski ,
An easier approach may be to use arcpy.  Ex:
# Variables
portalURL = 'https://gis.esri.com/portal'
username = 'portaladmin'
password = 'p0rt@l@dmin1'
featureServiceURL = 'https://gis.esri.com/server/rest/services/pipes/FeatureServer/0'
# Sign into Portal
arcpy.SignInToPortal(portalURL, username, password)
# Calculate Field
arcpy.management.CalculateField(
    in_table=featureServiceURL,
    field="FLAGFIELD",
    expression="'YES'",
    expression_type="PYTHON3",
    code_block="",
    field_type="TEXT",
    enforce_domains="NO_ENFORCE_DOMAINS"
JakeSkinner
Hi @kapalczynski ,
# Variables
# Sign into Portal
# Calculate Field
    field="FLAGFIELD",
    expression="'YES'",
    code_block="",
    field_type="TEXT",
kapalczynski
@JakeSkinner  thanks... that is way easier... not sure when to use one or the other... still a bit confused there
kapalczynski
@JakeSkinner   How could I add a WHERE clause to that ... so update the field value only when XXX
JakeSkinner
I tend to stick to arcpy when the functionality is available in both arcpy and ArcGIS API for Python.  It minimizes the code you will have to write.
For the WHERE clause, you can first create a Feature Layer using the Make Feature Layer tool.
kapalczynski
@JakeSkinner
So create a layer from the inputFeatureLayer where the field "Imported = No" and dump the results into an InMemory Layer
From there I need to query the InMemory layer (r"memory\importedRecords") and append that to the main Feature...
Something like this
    inputFeatureLayer = r'https://gggg.gov/hosting/rest/services/Hosted/Public_DEV_View/FeatureServer/0'
    outputFeatureLayer = r'https://gggg.gov/hosting/rest/services/Hosted/Public_/FeatureServer/0'
    whereClause = "Imported = 'No'"
    arcpy.MakeFeatureLayer_management(inputFeatureLayer, r"memory\importedRecords", whereClause )
    arcpy.management.Append(r"memory\importedRecords"], outputFeatureLayer, "TEST_AND_SKIP")
JakeSkinner
@kapalczynski you can run the Calculate Field on the feature layer and the edits will be reflected in the service:
# Variables
# Sign into Portal
# Make Feature Layer
arcpy.MakeFeatureLayer_management(featureServiceURL, "fLyr", whereClause)
# Calculate Field
    in_table="fLyr",
    field="FLAGFIELD",
    expression="'YES'",
    code_block="",
    field_type="TEXT",
kapalczynski
@JakeSkinner
Does it matter if the Layer is Hosted?  I am try that and getting errors..
The Hosted FS is Public and not token needed.
    portalURL = 'https://xxxx.gov/portal'
    username = 'xxxx'
    password = 'xxxx'
    inputFeatureLayer = r"https://dfdfdf.gov/hosting/rest/services/Hosted/DEV_H/FeatureServer/3"
    whereClause = "Imported = 'Yes'"
    #arcpy.MakeFeatureLayer_management(inputFeatureLayer, r"memory\importedRecords", whereClause )
    arcpy.MakeFeatureLayer_management(inputFeatureLayer, "fLyr", whereClause )
        in_table= "fLyr",
        field="Imported",
        expression="'No'",
        code_block="",
        field_type="TEXT",
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset https://xxxx.gov/hosting/rest/services/Hosted/DEV_H/FeatureServer/3 does not exist or is not supported
Failed to execute (MakeFeatureLayer).
kapalczynski
@JakeSkinner
EDIT
I forgot to mention that this was a table that I was trying to update... not a feature class ... Is there a make table?
kapalczynski
Think I got it with this
arcpy.management.MakeTableView(inputFeatureTable, "fLyr", whereClause )
in_table= "fLyr",
field="IMPORTED",
expression="'Yes'",
code_block="",
field_type="TEXT",
