Update attribute table
1537
02-03-2023 07:56 AM
MarcEsmeijer
Dear all,
I have renamed field values with my code which is shown in the figure below. The values are stored but if I reopen my attribute table, the same old values appear. It seems that the attribute table is only updated when I restart my project in ArcGIS. This is rather inefficient so I am trying to find either a function in ArcPY that updates my rows or whether there is a refresh table button.
It seemed there was a Reload cache button but I cannot seem to find it.
I am looking forward to your replies.
Kind regards,
Marc
AlfredBaldenweck
MVP Frequent Contributor
Yeah, this is a problem. I ran into something similar last year.
Calculate Field not working when iterating through... - Esri Community
Does it work to just remove and add the data back in? Maybe saving a layer file so you can just drag that in to check the updates without losing your formatting.
by Anonymous User
Not applicable
Caching can be frustrating. Sometimes you have to refresh the parent folder/gdb for it bring in the changes.  If there isn't a refresh option in the right click menu, check the burger menu after clicking on the item:
