I have been creating a script based off the Production Mapping team's Batch Make Grids and Graticules script, but adapted for use in ArcGIS Pro. Looping the geoprocessing has caused processing times to balloon - though I'm working on a server with plenty of CPU and RAM (100+gb).
In short, this .pyt script loops through a polygon feature class representing a grid, and for every tile in the grid (i.e., for each polygon in the feature class), it runs the arcpy.topographic.MakeGridsAndGraticulesLayer() and then exports this layer using arcpy.management.SaveToLayerFile(). Thus the output is a) the feature dataset containing the grid and graticule features, and b) a folder of .lyrx files that refer to the feature dataset, for each tile in the grid.
The first 15 runs take an average of 10 seconds to complete. By run 70, we are looking at ~30 seconds per run. This continues until it takes 10+ minutes per run after a few hundred iterations. I track the memory usage and it is increasing slowly - about 150mb per 100 loops. The problem is, I need to run this process about 4000 times.
Below is the executable function of the .pyt tool. I've also attached the .pyt file in its entirety. You can see I've accounted for removing the layers in memory, garbage collection, turned off log history, etc. Something is still causing a slowdown, and I am at a loss.
def execute(self, parameters, messages):
"""The source code of the tool."""
try:
arcpy.SetLogHistory(False)
arcpy.SetLogMetadata(False)
arcpy.env.addOutputsToMap = False
Grid_Template_XML_file = parameters[0].valueAsText
input = parameters[1].valueAsText
Input_Feature_Dataset = parameters[2].valueAsText
Name_Field = parameters[3].valueAsText
Rotation_Field = parameters[4].valueAsText
Output_Folder = parameters[5].valueAsText
aprx = arcpy.mp.ArcGISProject("CURRENT")
map_obj = aprx.listMaps()[0]
# Local variables
inDesc = arcpy.Describe(input)
FieldName = inDesc.shapeFieldName
feature_cnt = int(arcpy.management.GetCount(input)[0])
messages.addMessage("\n*****************************")
messages.addMessage("No. of Features selected = " + str(feature_cnt))
messages.addMessage("*****************************")
String_Array = os.path.splitext(os.path.basename(Grid_Template_XML_file))[0]
failed_features = []
feature_cntr = 0
# Check that the input has features
if feature_cnt > 0:
# Open a Search Cursor to iterate through the AOI feature class/layer and create grids
with arcpy.da.SearchCursor(input, ["SHAPE@", Name_Field]) as cursor:
for row in cursor:
feature_cntr += 1
AOI_Feature = row[0]
Grid_Name = row[1]
Rotation = row[2] if Rotation_Field else None
# Set the step progressor
arcpy.SetProgressor("step", f"Creating grids and graticules for feature with MSNAME = {Grid_Name}", 0, feature_cnt, 1)
arcpy.SetProgressorPosition(feature_cntr)
start_time = time.time()
# Concatenate the grid's name to the output layer's name for unique identification
Output_Layer = f"memory\\{String_Array}_{Grid_Name}"
try:
if Rotation_Field and Rotation is not None:
arcpy.topographic.MakeGridsAndGraticulesLayer(in_grid_xml=Grid_Template_XML_file, area_of_interest=AOI_Feature, target_feature_dataset=Input_Feature_Dataset, out_layer_name=Output_Layer, grid_name=Grid_Name, Rotation=Rotation)
else:
arcpy.topographic.MakeGridsAndGraticulesLayer(in_grid_xml=Grid_Template_XML_file, area_of_interest=AOI_Feature, target_feature_dataset=Input_Feature_Dataset, out_layer_name=Output_Layer, grid_name=Grid_Name)
if Output_Folder:
arcpy.management.SaveToLayerFile(Output_Layer, Output_Folder + "\\" + f"{String_Array}_{Grid_Name}", "ABSOLUTE")
arcpy.management.Delete(Output_Layer)
arcpy.management.Delete("memory")
layers = map_obj.listLayers()
for layer in layers:
map_obj.removeLayer(layer)
gc.collect()
except Exception as e:
messages.addMessage("There was an error with this tile")
messages.addErrorMessage(str(e))
failed_features.append(Grid_Name)
# Log memory usage
process = psutil.Process(os.getpid())
mem_info = process.memory_info()
messages.addMessage(f"Memory usage after processing feature {Grid_Name}: {mem_info.rss / (1024 * 1024):.2f} MB")
end_time = time.time()
elapsed_time = end_time - start_time
messages.addMessage(f"Time taken for feature {Grid_Name}: {elapsed_time:.2f} seconds")
messages.addMessage(f"\nTotal Warnings: {len(failed_features)}")
messages.addMessage(f"Grid creation failed for features: {failed_features}")
else:
raise No_Features(feature_cnt)
except No_Features as e:
messages.addMessage("The input has no features")
arcpy.ResetProgressor()
if not failed_features:
if Output_Folder:
messages.addMessage(f"Grid creation successful for all features. Layers can be readded from : {Output_Folder}")
else:
messages.addMessage("Grid creation successful for all features. Please use the Add Grid Data tool in Production Mapping to add the outputs to your map")
messages.addMessage("Script Complete")
