The situation:
I have a table that is in a oracle database that I need to query and then spatialize. I need to select the most recant updated record for each group. I have a last update column to base the max date on. Then I have a name and a sand type columns that should make up the groups. So after some looking I think this is the sql that I need:
SELECT NAME, SAND, MAX(LAST_UPDATE) AS "DATE" from MY_TABLE
GROUP BY NAME, SAND
I have run it in Toad and it produced the desired result.
After the query I will need to do a join to a table that has the lat and long data and then make a xy events layer and then export the thing to a feature class in our SDE.
The question:
What it the best way to do this query in python in such a way that I can pass the output to arcpy for the join etc.
Thanks for the help,
Forest
