Spatially Enabled Dataframe to Feature Service - how to avoid shapefile conversion?
1865
11-15-2022 11:37 AM
I_AM_ERROR
Hi All,
Fairly new to publishing spatially enabled dataframes, looking for advice on the following
  • python env either does not have arcpy, or has arcpy but does not have a license (not checked out or connected to license server
  • create a spatially enabled dataframe from various data inputs
  • publish to AGOL/Portal using either df.spatial.to_featurelayer() or gis.content.import_data()
Both of the above methods seem to export the dataframe out to shapefile first before publishing to feature class. This is causing a couple issues on the back end (field values are being converted to different datatypes resulting in a failed publish)
Is there a better way to publish spatially enabled dataframes in an environment that is not using arcpy?
Thanks!
jcarlson
A better way would probably be to avoid it entirely. I've had lots of similar trouble publishing from a dataframe directly to a layer.
Personally, I would built the destination layer first in order to control the data types, then use the Python API to append data to it.
- Josh Carlson
Kendall County GIS
I_AM_ERROR
I was considering that and, yeah it would probably give better control over the destination schema.
I_AM_ERROR
Just feels pretty odd having to write a file out to disk just to immediately read it back in....😐
