SearchCursor
5853
13
07-09-2020 01:38 AM
KristýnaSeimlová
I try to find a match of numbers in the first column and second column, if it finds the same number in second column, it writes the value of the first column into third column. Do you have any ideas?
JoshuaSharp-Heward
That really should run fine, I don't see how that's giving a syntax error, unless it doesn't like the indentation. In any case I defer to Dan's solution which is running the same thing but in one line:
!NADR_ID! if !NADR_ID! in !ABOVE! else None
KristýnaSeimlová
It doesn't work for me, but thank you so much for your help anyway.
JoshuaSharp-Heward
I realise that should be "NADR_GID" not "NADR_ID", where are you putting that line of code? It should be in the box below the code block, and the code block should be empty! If that fails, I'd be happy to take another look at the error message it gives.
Also I realised in your previous screenshot it's running as Python9.3, try the above line or my original solution with "Python" as the expression type just in case!
DanPatterson
MVP Esteemed Contributor
Why do you need a search cursor? you can use the field calculator for that
python parser
!NADR_ID! if !NADR_ID! == !ABOVE! else None
... sort of retired...
