Scripting (Python) Feature Class content into Shapefiles based on an UTM data structure
9666
21
04-26-2016 02:49 AM
EduardoAbreu-Freire
Consider a Feature Class (part of an Enterprise GDB content) and two of its fields are "UTM_grid" and the "OID".
Scripting with python 2.7 for ArcGIS 10.3.
"UTM_grid" field was broken down into "UTM_block" + "UTM_sheet" and then using a dictionary and list structure UTM_block-->UTM_sheet-->OID was organized with this syntax:
{ 'UTM_block_1' : { 'UTM_sheet_A' : [ oid_1 , oid_2 ] }, { UTM_sheet_2 : [ oid_3 , oid_4, oid_5 ] } }
We need to create **shapefiles** with features (identified by the object value - oid) based on the follow data structure (OIDs will be organized regarding an UTM/location based structure):
- UTM_block_* will be a folder
- UTM-sheet_* its subfolder.
- List of objects (OIDs) will populate the shapefile.
Another point we have to deal with is that the shapefile should only have some fields of the original Feature Class:
We have used fieldmappings and arcpy.FeatureClassToFeatureClass_conversion() to create a non-UTM-organized shapefile from a Feature Class with the fields that we need.
Now the problem is how to process the **feature export** to get UTM-organized shapefiles! How can we manage it?
Bellow is what we have now inside a function:
    with arcpy.da.SearchCursor(feature_class, ['UTM_grid , 'OBJECTID']) as cursor:
        dic = dict()
        for row in cursor:
            UTM_grid_value = row[0]
            oid_value = row[1]
            try:
                b_s_split = UTM_grid_value.split('_')     # split into block & sheet
            except Exception, e:
                pass
                print(UTM_grid_value)
                print(e)
            else:
                # create folders & subfolders (blocks & sheets) in a directory
                dic.setdefault( b_s_split[0], {} ).setdefault( b_s_split[1], [] ).append( oid_value )
                dir_path = os.path.dirname("E:\\")     # full path to directory
                dirs = [ [b_s_split[0]] , [b_s_split[1]] ]
                for item in itertools.product(*dirs):
                    if not os.path.isdir(os.path.join(dir_path, *item)):
                        os.makedirs(os.path.join(dir_path, *item))
BlakeTerhune
My suggestion would be to do something like this where you can specify the beginning of the value. Assuming the structure of the FOL_250K field values will stay the same, you can specify just the block or the block and sheet.
# Get list of distinct UTM values
utm_field = "FOL_250K"
utm_prefix_filter = arcpy.GetParameterAsText(0)
if utm_prefix_filter:
    where_clause = "FOL_250K LIKE '{}%'".format(utm_prefix_filter)
else:
    where_clause = ""
sql_prefix = "DISTINCT {}".format(utm_field)
sql_suffix = None
distinct_utm = [
    i[0] for i in arcpy.da.SearchCursor(
        feature_class, utm_field, where_clause, sql_clause=(sql_prefix, sql_suffix)
BlakeTerhune
Sorry, I just realized that where_clause doesn't use the utm_field variable I had set up. Line 5 from the code above should be:
where_clause = "{} LIKE '{}%'".format(utm_field, utm_prefix_filter)
