Script Tool, Print Selected Features
1192
01-03-2023 10:21 AM
aecho2
Need help printing only selected features in a layer, currently have the following:
import arcpy
#Set variables
arcpy.mp.ArcGISProject('CURRENT')
aprx = arcpy.mp.ArcGISProject('CURRENT')
TCG4232_USNG_GRIDS = "P:/PROJECTS/RP_Quality_Control_cGIS/MapSalesArcProProject/MapSalesLive1211/MapSalesLive/Data/GRIDS/USNG_GRID_OH.gdb"
Output_Folder = arcpy.GetParameterAsText(0)
#list of layer names that you want to be turned off.
p = arcpy.mp.ArcGISProject("Current")
m = p.listMaps("Map")[0]
layer_names = ['TCG4232_USNG_GRIDS']
lyrList = m.listLayers()
for lyr in lyrList:
    lyr.visible = True
    if lyr.name in layer_names:
        lyr.visible = False
#Print to PDF
try:
    l = aprx.listLayouts()[0]
    l.mapSeries.refresh()
    if l.mapSeries is not None:
        ms = l.mapSeries
        if ms.enabled:
            ms = l.mapSeries
            indexLyr = "TCG4232_USNG_GRIDS"
            ms.exportToPDF(Output_Folder,"SELECTED",
                "PDF_SINGLE_FILE",
                150,
                "FASTEST",
                True,
                "ADAPTIVE",
                True,
                "LAYERS_ONLY",
                True,
                80,
                True,
                False)
except Exception as e:
    print(f"Error: {e.args[0]}")
Tags (1)
RhettZufelt
MVP Notable Contributor
the lyr.visible turns the layer on/off only (either view all or none).
If you want to just display a subset of the data in a layer, you would put a definition query on the layer and have that layer as visible = True.
R_
aecho2
I Intended to turn off the layer, my print needs the layer off but I still need the region of the layer area to print.
I just need my print to target the "TCG4232_Grids" layer.
