Running SummarizeWithin against "memory" datasets
2276
02-25-2021 08:52 AM
JakeAdamsUGRC
I have a script that runs SummarizeWithin() as a step in the analysis process. If I pass it paths to feature classes within an on-disk gdb for the input and output data it runs fine, but if I try to use "memory" datasets ("memory/in_points" and "memory/out_hexes"), it fails with "ERROR 000187: Only supports Geodatabase tables and feature classes".
Does SummarizeWithin() not work with "memory" datasets?
DanPatterson
MVP Esteemed Contributor
try  :  r"memory\in_points"
etc.
Write geoprocessing output to memory—ArcGIS Pro | Documentation
It supports featureclasses etc and there is no list of tools that don't support memory workspaces
... sort of retired...
JakeAdamsUGRC
Good catch on the slash, and that is how I understood "memory" to work- pretty much a drop-in replacement for on-disk datasets (but with some limitations as noted in the docs).
However, SummarizeWithin() is still failing on me with "memory" output feature classes. It works with on-disk or memory source points but fails if I use a memory destination.
I've been testing in a stand-alone script and also in iPython, both in a conda environment created via miniconda and arcpy installed via conda install arcpy -c esri.
DanPatterson
The only thing you might try is MakeTable in memory first, then use it.
I rarely use since I dont find it speeds anything up much
JakeAdamsUGRC
I was using memory to avoid having to clean up a bunch of intermediate files, but I've built a workaround with a temporary GDB that I can nuke when I'm finished. I'll stick with that until I have time to troubleshoot more. Thanks for the suggestions!
__JackCharde__
I see this is a 4yo post, but this still persists. SummarizeWithin does support memory dataset, but you have to use in_memory, which is a legacy memory-based workspace for ArcMap, and anything written to in_memory can't actually be added to a map. It will first be converted to a file GDB dataset, and then added. This doc explains the memory workspace. Definitely frustrating, as I am encountering it, too.
