Renaming a shapefile in Python 2.7
5080
10
09-09-2019 07:20 PM
BlytheSchembri1
Hi guys
I have a python script (written in 2.7) with takes a shapefile, renames it and then imports it into a SDE geodatabase. The creators of the shapefile have recently changed the file name to have a full stop halfway through the name which now causes the script to crash.
I have tried running the following section of python to rename the shapefile but it only renames the .shp file and no other files that are part of the shapefile:
arcpy.env.workspace = "C:\\Users\\blythe schembri\\Downloads"
datasets = arcpy.ListFeatureClasses()
for fc in datasets:
      CorrectName = fc.replace('dbo.vNT_','')
arcpy.Rename_management(fc, CorrectName[:-4])
How do I make it rename all the shapefile components?
Blythe
DanPatterson_Retired
Copy Features—Data Management toolbox | ArcGIS Desktop
would be your best option to recreate the old shapefile under a new name and to make a featureclass.
Your original would be retained, and could be archived if needed or dumped via windows explorer
