RemoveEmptyFeatureClassFromGeometricNetwork_management returns ERROR 000584
1649
02-26-2021 04:23 AM
LukeHodgson
I'm trying to run the following code
import os
import arcpy
CONFOLDER = os.path.abspath(r"C:\...\AppData\Roaming\ESRI\Desktop10.2\ArcCatalog")
NETWORK_EQUIPMENT = os.path.join(CONFOLDER, 'test_db_at_test-1.sde\\NetworkEquipment\\Network_Equipment')
# Process: Remove Feature Class From Geometric Network
desc = arcpy.Describe(NETWORK_EQUIPMENT)
arcpy.RemoveEmptyFeatureClassFromGeometricNetwork_management(NETWORK_EQUIPMENT, "RfConn")  # select count(*) from RfConn -- this returns 0, so I believe it's empty.
But get this error.
File "\remove_empty_featureclass_from_geometricnetwork.py", line 10, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\management.py", line 5096, in RemoveEmptyFeatureClassFromGeometricNetwork
raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000584: Implementation of this Tool's Validate is invalid.
Failed to execute (RemoveEmptyFeatureClassFromGeometricNetwork).
I'm using ArcGIS 10.2.2, ArcSDE10 on SQL Server and the geometric network consists of versioned data.
Any idea what I'm doing wrong here?
DanPatterson
MVP Esteemed Contributor
This error typically only occurs in a custom tool. Contact the tool's developer for more assistance.
000584: Implementation of this Tool's Validate is invalid.—ArcGIS Pro | Documentation
I guess that would be you
Programming a ToolValidator class—ArcGIS Pro | Documentation
But this link says
Tools that are not available in ArcGIS Pro—ArcGIS Pro | Documentation
it isn't available(?)
Remove Empty Feature Class From Geometric Network
... sort of retired...
DanPatterson
But this link says
