Reconcile ArcPy Not Working
1981
04-03-2020 04:55 PM
DevinUnderwood3
When I run the Reconcile tool it works fine. Subsequently, I export the results as a python snippet and run it as a standalone script. The script processes and doesn't return an error but the version doesn't reconcile nor delete. I have come across suggestions that the version name should be in Unicode and that this is a known possible bug. Why wouldn't the script work when it obviously ran just fine when using the tool?
DanPatterson_Retired
arcmap or Pro?
Reconcile Version (Deprecated) or Reconcile Versions (replacement)
There is a list of bugs depending on what you are using in your code vs the tool
https://support.esri.com/en/Search-Results#search?q=%22reconcile%20version%22&content-type=Bugs
PS  when running a tool inside ArcWhatever, there are things that are known (permissions, ownership etc) whereas a standalone script doesn't
DevinUnderwood3
I didn't realize that there were 2 different Reconcile tools to chose from, I didn't take notice.
I  will certainly look at the bugs document.
I ran the tool in ArcMap. Interesting concept about permissions and ownership.
DevinUnderwood3
I believe the following applies to me.
Synopsis
Arcpy.ReconcileVersions_management() fails to reconcile version created by operating system authenticated users.
Add [] around the version, so for example: ["AVWORLD\cont_joglekar".R1"]
hard to tell since you didn't share your code
I will mark it closed
