Query feature if an attribute is null after 180 days of date on another attribute?
3162
10
10-05-2018 09:50 AM
by Anonymous User
Not applicable
Looking for a sample ArcPy script I can modify for my use. Any suggestions?
RandyBurton
Typo on my part, an extra minus in days=180  (updated original code):
date_past = datetime.now() - timedelta(days=180)
RandyBurton
Perhaps  (you could remove time from formatting, if desired):
from datetime import datetime, timedelta
date_past = datetime.now() - timedelta(days=180) # you can add/subtract as required
wc = "Field IS NULL AND DateField < DATE '{}'".format(date_past.strftime("%Y-%m-%d %H:%M:%S"))
print wc
# Field IS NULL AND DateField < DATE '2018-04-08 09:25:35'‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
by Anonymous User
Not applicable
The month and day are correct but the year is 2019 instead of 2018?
RandyBurton
by Anonymous User
Not applicable
Awesome! Thanks for your help on this.
by Anonymous User
Not applicable
I used the code you supplied but noticed it's returning everything 180 days or older. I only want results that fall exactly 180 days from current date.
arcpy.SelectLayerByAttribute_management(permits, "NEW_SELECTION", "Date_Accepted = date '{}' AND Fee_Paid Is NULL".format(notice.strftime("%Y/%m/%d")))
JoeBorgione
My bet is to change the   <  to   =   and you should be good to go:‍
wc = "Field IS NULL AND DateField = DATE '{}'".format(date_past.strftime("%Y-%m-%d %H:%M:%S"))
RandyBurton
When dealing with date/time, I probably wouldn't use "=" in the query.  See Joshua Bixby‌'s second comment in this thread with ESRI's explanation.
JoeBorgione
After I read you post with 'between' I realized that.....  thanks!
RandyBurton
And after I re-read Esri's comment, I started thinking milliseconds.  So "23:59:59" could also miss "23:59:59.9".
