Python Toolbox Tool Parameter Hints
4375
12-02-2022 03:16 PM
RogerDunnGIS
The tools that come with ArcGIS Pro have hints for each parameter.  Clicking the blue (i) symbol to the left of the parameter's name brings up a nice hint window.  (See Buffer > Side Type for an example).  I would like to create similar documentation for my Python Toolbox tools.  I cannot figure out which property of arcpy.Parameter to set for this.  Please explain how I should accomplish this.  Thank you.
DanPatterson
MVP Esteemed Contributor
I use custom python toolbox since you get validation code, visuals and a load more
Comparing custom and Python toolboxes—ArcGIS Pro | Documentation
I suspect you can edit the meta for a python toolbox as well
... sort of retired...
BlakeTerhune
RogerDunnGIS
I had seen these properties, but the documentation seems to indicate that they are for warning and error messages.  Thank you for posting, though.
DanPatterson
RogerDunnGIS
This will indeed work for me, but I didn't mark this as a solution.  Who did, and how did that happen?
