Python Toolbox-populate drop-down with field values
13946
01-03-2016 08:36 PM
BrianKaplan
There are a few discussions on this topic but I'm not finding the solution I need or it is right in front of my face and I'm missing it completely.
I'm using Desktop 10.3.   I'm am trying to create a geoprocessing tool with the input dialogue box requesting the user to select:
1. Feature class  e.g US States
2. Field with the States name in the Feature Class  e.g. stateNames
3. A drop-down of the 50 states where the user can select one of the states.
I'm trying to use the python toolbox tool template (portion shown below).  I'm able to populate a drop-down of the fields and now need to have the user select a value from the field.
Any suggestions?
Thanks
Brian
class tool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "tool"
        self.description = ""
        self.canRunInBackground = True
    def getParameterInfo(self):
       # first paramter
        in_feature = arcpy.Parameter(
           displayName = "Feature with States",
           name = "in_feature",
           datatype = "Feature Layer",
           parameterType = "Required",
           direction = "Input")
        stateField = arcpy.Parameter(
           displayName = "Field with State Names",
           name = "stateField",
           datatype = "Field",
        stateField.filter.list = ['Text']
        stateField.parameterDependencies = [in_feature.name]
        stateName = arcpy.Parameter(
           displayName = "Select one State",
           name = "stateName",
           datatype = "GPValueTable",
      return
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
Luke_Pinner
MVP Regular Contributor
I thought there was a way to do this easily with parameterDependencies, but can't get that to work. But below is another way:
class Tool(object):
    def __init__(self):
        self.label = "Tool"
        self.canRunInBackground = False
        """Define parameter definitions"""
           datatype = "Field",
           name = "stateName",
           datatype = "GPString",
        stateName.filter.type = "ValueList"
        stateName.filter.list = []
        return [in_feature, stateField, stateName]
        if parameters[1].value:
            with arcpy.da.SearchCursor(parameters[0].valueAsText, parameters[1].valueAsText) as rows:
                parameters[2].filter.list = sorted(list(set([row[0] for row in rows])))
        else:
            parameters[2].filter.list = []
        return
Luke_Pinner
class Tool(object):
    def __init__(self):
        self.label = "Tool"
           datatype = "Field",
           name = "stateName",
        else:
        return
BrianKaplan
Luke,  Thank you so very much. It works great.  Brian
Yuriko
Thanks for this!
jaykapalczynski
Honored Contributor
I am new to this....how is the class called from Python and used?
Is there a simply example of this code in its entirety where when you run it you just see the dropdown and the populated list?
