Python Script to Calculate Geometry Attributes from Selected Feature
14745
29
09-14-2021 06:32 AM
ABishop
Hello All,
I am running ArcGIS Pro 2.8.  I am also experimenting with Visual Studio to build an add-in with a button.  I want the button to run a python script which calculates the geometry attributes (acres) of a selected polygon and then I plan to make the add-in button available to our users in the office.  I was going to build a model in ArcGIS Pro which uses the "Calculate Geometry Attributes" tool to do this, but I quickly realized a few issues: #1 use the feature that is hard coded to my profile path and #2 not sure it will allow me to add a parameter to require the use to select the feature they want calculated due to the the issue with #3 the data source is a polygon stored in an SDE which is versioned.  Any suggestions?
Amanda Bishop, GISP
ABishop
Probably check the data source of the layer for the feature class name.
Amanda Bishop, GISP
BlakeTerhune
Is there any chance the same parcel feature class would be added as a layer to the map more than once? Or would the parcel layer be present in more than one map in the project?
ABishop
Sorry I just sent you a message and then I saw your question.  Yes, there is a chance.  Each user has control over their own project, and without me looking at their projects individually, I can't say for sure.
Amanda Bishop, GISP
ABishop
OK... So after I sent you that last message with the python code from the ModelBuilder, I ran the model itself while in the project with the feature class selected and a "null" in the GIS_ACRES field.... and it ran but then I got a warning.  I am assuming it is because the GIS_ACRES field only accepts so many characters and I really do need the acreage calculation to be two decimal points.  Is there a way to control this?  (see pics attached for the warning and the calculated value in the selected feature)
Amanda Bishop, GISP
ABishop
@BlakeTerhune
Again... thank you so much for your assistance!
OK.. so I did some more research and I found out that there is a logical function in the ModelBuilder.  Its called "If Selection Exists".  To test this, I built a model with "Select by Attributes" (where "GIS_ACRES IS NULL") then used the logical function "If Selection Exists" to check if a selection is made on the "parcel" feature class and if the logical function returns true, then the "Calculate Geometry Attributes" occurs on the "GIS_ACRES" field.  To make sure this worked on the particular parcel i had selected, I made the GIS_ACRES field "null".  I exported the script from the model and ran it inside the project I had open with the parcel feature class selected and the script returned an error:
File "<string>", line 6
def # NOT IMPLEMENTED# Function Body not implemented
SyntaxError: invalid syntax
HELLLLPPPPPP! 😥  See python code window for the model builder code that I used.
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2021-09-16 13:37:29
import arcpy
def GeometryCalc():  # GeometryCalc
    # To allow overwriting outputs change overwriteOutput option to True.
    arcpy.env.overwriteOutput = False
    arcpy.ImportToolbox(r"c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Data Management Tools.tbx")
    # Model Environment settings
    with arcpy.EnvManager(scratchWorkspace=r"C:\Users\abishop\AppData\Local\Temp\ArcGISProTemp10544\1ba0f558-c873-4c6c-be6d-dc08393016c0\Default.gdb", workspace=r"C:\Users\abishop\AppData\Local\Temp\ArcGISProTemp10544\1ba0f558-c873-4c6c-be6d-dc08393016c0\Default.gdb"):
        parcel = "I:\\users\\abishop\\DATA\\CadastreCopy.gdb\\parcel"
        # Process: Select Layer By Attribute (Select Layer By Attribute) (management)
        parcel_Layer, Count = arcpy.management.SelectLayerByAttribute(in_layer_or_view=parcel, selection_type="NEW_SELECTION", where_clause="GIS_ACRES IS NULL", invert_where_clause="")
        # Process: If Selection Exists (If Selection Exists) ()
        True_48, False_49 = #  NOT  IMPLEMENTED(in_layer_or_view=parcel_Layer, selection_condition="EXISTS", count=0, count_min=0, count_max=0)
        # Process: Calculate Geometry Attributes (Calculate Geometry Attributes) (management)
        if True_48:
            parcel_Layer_2_ = arcpy.management.CalculateGeometryAttributes(in_features=parcel_Layer, geometry_property=[["GIS_ACRES", "AREA"]], length_unit="", area_unit="ACRES", coordinate_system="PROJCS[\"NAD_1983_StatePlane_Florida_West_FIPS_0902_Feet\",GEOGCS[\"GCS_North_American_1983\",DATUM[\"D_North_American_1983\",SPHEROID[\"GRS_1980\",6378137.0,298.257222101]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"False_Easting\",656166.6666666665],PARAMETER[\"False_Northing\",0.0],PARAMETER[\"Central_Meridian\",-82.0],PARAMETER[\"Scale_Factor\",0.9999411764705882],PARAMETER[\"Latitude_Of_Origin\",24.33333333333333],UNIT[\"Foot_US\",0.3048006096012192]]", coordinate_format="SAME_AS_INPUT")[0]
if __name__ == '__main__':
    GeometryCalc()
Amanda Bishop, GISP
BlakeTerhune
Sorry, I didn't get a message and haven't had a chance to look closely at the screenshots. But regarding that error, simply deleting line 6 in that code you posted will resolve the syntax error.
ABishop
I tried that and it didn't work.
Amanda Bishop, GISP
BlakeTerhune
Didn't work as in you got an error or it did something unexpected? If an error, include the entire error message with traceback.
ABishop
See python window for code I ran without the lines you said to remove and the error message.
Generated by ArcGIS ModelBuilder on : 2021-09-17 08:27:10
import arcpy
        if True_48:
    GeometryCalc()
  File "<string>", line 25, in <module>
  File "<string>", line 21, in GeometryCalc
NameError: name 'True_48' is not defined
Amanda Bishop, GISP
BlakeTerhune
I think as @DarrenWiens2 mentioned in the other thread, something appears to have gotten messed up when exporting this script from the model. Maybe try exporting it again.
