Python questions (How covert txt files to .csv files?)
6213
10
03-05-2021 02:54 AM
Mick
My company asks to convert txt files to .csv files. Could you advise how to write a Python script for ArcGIS?
JoeBorgione
You won't use arcpy as it is nothing more than a python module but you can use the re (regular expression) module to do it:
import re
myFile = r'C:\temp\Coords.txt'
with open(myFile,'r+') as f:
    text = f.read()
    text = re.sub('  ',',',text)
    f.seek(0)
    f.write(text)
    f.truncate()
f.close()
Assuming you have the file C:\temp\Coords.txt that looks like this:
-111.45  40.57
-112.05  40.06
I stole this right from https://www.kite.com/python/answers/how-to-update-and-replace-text-in-a-file-in-python
That should just about do it....
DanPatterson
MVP Esteemed Contributor
The bigger question is the *.txt files in comma separated values format?
Otherwise it would be a simple renaming operation.
And in any event, the filename extension doesn't need to be *.csv for it to be read as one, it is the contents that are important
A previous answer provides the solution, which just needs to be put within a loop
Solved: Using Python to split and rename file - Esri Community
... sort of retired...
Mick
There is no comma.
DanPatterson
Then a sample of the input would be needed, otherwise you have to read the file, parse it on spaces or tabs and reassemble
Mick
I have only two spaces between coordinates in my files. Can you recommend a code to replace two spaces for a comma in the script?
DanPatterson
I use numpy
fname = r"c:\temp\space.txt"
a = np.loadtxt(fname, delimiter=" ")
outname = fname[:-3] + "csv"
np.savetxt(outname, a, fmt='%f', delimiter=", ")
a text file
1.0 2.0 3.0
4.0 5.0 6.0
as csv file
1.000000, 2.000000, 3.000000
4.000000, 5.000000, 6.000000
you can format as you see fit.
Mick
Thank you, can you recommend any extra options with arcpy?
JoshuaBixby
NumPy has been a standard package in Esri's Python deployment for years.  If your Python deployment has ArcPy, it has NumPy installed too.
JoeBorgione
import re
    text = f.read()
    f.seek(0)
    f.write(text)
    f.truncate()
f.close()
-111.45  40.57
-112.05  40.06
Mick
Can you recommend how to use not only one file to convert but a folder with one hundred files?
