Problem with creating InsertCursor
7065
14
09-15-2014 11:50 PM
ChristofLink
I want to write a small tool, which insert some data into an MS-Access database (.mdb). But i have a problem to initialize the cursor.
The Code is very simple :
strOutputPath = r"I:\Data\Test.mdb\FS_BASEMAP\FCL_B_COVERSHEET_A"
icur = arcpy.InsertCursor(strOutputPath)
There is some more code but it stoped at this point and I get this error message:
  File "I:\Skript\AddFeatureSkript.py", line 70, in <module>
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\__init__.py", line 1214, in InsertCursor
    return gp.insertCursor(dataset, spatial_reference)
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 369, in insertCursor
    self._gp.InsertCursor(*gp_fixargs(args, True)))
RuntimeError: ERROR 999999: Fehler beim Ausführen der Funktion.
COM-Komponente der Objektklassenerweiterung konnte nicht erstellt werden. [FCL_B_COVERSHEET_A]
The error message is in german so I translate it:
ERROR 999999: Error when executing the function.
COM component object class extension could not be created. [FCL_B_COVERSHEET_A]
I don't know what the problem is, so hopefully some can help me.
Thanks, Regards
JakeSkinner
Esri Esteemed Contributor
Hi Christof,
I believe you are running your script with Python 64-bit, which no longer supports personal geodatabases (.mdb).  You will want to run the script with Python 32-bit.  Take a look at the section 'Python scripting' in the following link:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
ChristofLink
Hey Jake,
thanks for your answer, but I have only a 32 bit version of python installed on my computer and even the ArcGIS is 32 bit.
I just looked it up.
ChristofLink
*push*
JakeSkinner
As a test, can you copy the data to a File Geodatabase and see if you receive the error?
ChristofLink
So I tried it with a .gdb and used arcpy.da.InsertCursor and I works. I get no error message there, but unsing a .gdb isn't an option because the provided data is in the .mdb format.
JoshuaBixby
MVP Esteemed Contributor
What is the error message if you use arcpy.da.InsertCursor instead of arcpy.InsertCursor?  Do you have a requirement to use the older InsertCursor?  Besides better performance, the data access InsertCursor supports Python's with statement, which I find to be a big plus.
ChristofLink
If I use arcpy.da.InsertCursor. I get this error message:
  File "I:\Skripte\\AddFeatureSkriptv.py", line 70, in <module>
    icur = arcpy.da.InsertCursor(strOutputPath, ["SHAPE@"])
RuntimeError: cannot open 'I:\Test.mdb\FDS_BASEMAP\FCL_B_COVERSHEET_A'
JoshuaBixby
A few things come to mind.
  1. I: drive, mapped network drive or local storage?  If mapped network drive, have you tried copying the MDB to local storage and testing it.
  2. Can you create a new MDB and copy the data into it?  If so, does that give same error messages?
  3. Can you make an OLE DB connection to the MDB in question?
ChristofLink
Sry I was on vacation the last 2 weeks.
1. The I drive is a network drive but I also tried it with the local drive and I get the same error message.
2. I creaded a new MDB but even this dosen't work.
3. Yes I can make a OLE DB connection to the MDB.
