Pass dictionary key to arcpy.SelectLayerByAttribute_management
3557
9
06-11-2021 08:43 AM
TonyAlmeida
MVP Regular Contributor
 I am trying to compare the PIN fields of two layers, fc1 and fc2 and select fc2 features. The issues I have is that this process one PIN at a time it doesn't just select them all at once.
#arcpy.MakeFeatureLayer_management(fc2, "fc2_Lyr")
for WellID in fc2List:
    arcpy.SelectLayerByAttribute_management(fc2, "NEW_SELECTION", "\"PIN\" = '{}'".format(WellID))
#arcpy.MakeFeatureLayer_management(fc2, "SelPar_lyr", "\"PIN\" = '{}'".format(WellID))
DavidPike
MVP Notable Contributor
Not entirely sure what you mean, is it to select everything in fc2list?
If so, maybe just get rid of the for loop and use the SQL 'IN' statement.
arcpy.SelectLayerByAttribute_management("fc2_Lyr", "NEW_SELECTION", "\"PIN\" IN ({})".format(fc2List))
TonyAlmeida
My bad I thought I posted the whole code.
fc = "Wells"
fc2 = "Polygon"
fcList = []
fc2List = []
with arcpy.da.SearchCursor(fc, ["PIN"]) as cursor:
    for row in cursor:
        fcList.append(row[0])
        #print row[0]
with arcpy.da.SearchCursor(fc2, ["PIN"]) as cursor:
    for row in cursor:
        if row[0] in fcList:
            fc2List.append(row[0])
            print row[0]
    arcpy.SelectLayerByAttribute_management("fc2, "NEW_SELECTION", "\"PIN\" = '{}'".format(WellID))
JoeBorgione
A variation on @DavidPike 's theme.  Here I use list comprehension to create a list of the Wells pin values and then select the Polygons if the PIN is in the list.  You mentioned using a dictionary in the subject and you can use dictionary comphrension the same way. FYI: untested.  you may need to fiddle with the select statement...
import arcpy
fc = "Wells"
fc2 = "Polygon"
fields = ['PIN']
fcList = [i[0] for i in arcpy.da.SearchCursor(fc,fields)]
select = f'PIN IN {list}'
arcpy.SelectLayerByAttribute_management("fc2_Lyr", 'ADD_TO_SELECTION', select)
BlakeTerhune
I like this, but don't forget that formatting your select string with the list isn't valid SQL syntax because of the brackets. You need to reformat it with parenthesis. Assuming PIN is a string, you would need
select = f'PIN IN({",".join(fcList)})'
JoeBorgione
Thanks @BlakeTerhune That's exactly why I included the disclaimer!
TonyAlmeida
ok, thanks for the suggestion. It is not liking the  expression. This is currently in a shapefile.
Failed to execute (SelectLayerByAttribute). PIN is a string
result = arcpy.GetCount_management("fc2_Lyr").getOutput(0)
print ('{} has {} records'.format("fc2_Lyr", result[0]))
select = f'PIN IN({",".join(fc2List)})'
BlakeTerhune
Ah, I forgot the single quotes. As @JoeBorgione mentioned, these often take some fiddling. Hopefully this will keep the strings as single quotes.
select = f"PIN IN({str(fc2List)[1:-1]})"
Edit:
I just found this solution that is more robust and less of a hack.
str_values = ",".join(f"'{x}'" for x in fc2List)
select = f"PIN IN({str_values})"
DanPatterson
MVP Esteemed Contributor
Geoprocessing considerations for shapefile output—ArcGIS Pro | Documentation
dBASE files have little SQL support aside from a WHERE clause.
... sort of retired...
JoeBorgione
pinList = ['123','456','789']
'123' in pinList
Out[2]: True
'123' in ','.join(pinList)
Out[4]: True
Like I said, you'll need to fiddle a bit with the selection statement.  It typically takes me a time or two to get them right,
