Output file is missing in the output directory
4147
6
08-02-2021 04:31 AM
esmao
Hi, I am a new ArcGis user.
I try to get a lan/lon of the neghborhoods of a region. Although my code runs w/o any problem, the output file which is a .txt file is not created/ or not seen in the dedicated directory.
Here is my script:
## (i) Load arcpy and set working directory
import arcpy, os, getpass, shutil, copy, re
from shutil import copyfile
if getpass.getuser()=='xyz':
	working_dir = 'fill in path'
elif getpass.getuser()=='esm':
	working_dir = 'Z:/Documents/GitHub/amman'
os.chdir(working_dir)
arcpy.env.workspace = working_dir
arcpy.env.overwriteOutput = True #allows for overwriting files
## (ii) Useful shortcuts
temp_dir   = '/tex/theory/pop_increase/temp/'
output_dir = working_dir + '/tex/theory/pop_increase/input/travel_time/'
spatial_reference = arcpy.SpatialReference("WGS 1984")
## (iii) Set up GDB for calculations
gdbDir = temp_dir
gdbName = 'traveltime'
gdbPath = gdbDir + gdbName + '.gdb'
if arcpy.Exists(gdbPath):
	arcpy.Delete_management(gdbPath)
arcpy.CreateFileGDB_management(gdbDir, gdbName)
gdbPath =gdbPath +'/'
geography='Amman_zarqa'
source_dir=working_dir + '/raw/DoS/jordan_nh_shapfile/jordan_nh.shp'
# Step 2: Loading and transforming necessary layers
## (i) Projecting poligon layer for amman
in_data     = source_dir
out_data    = gdbPath + geography + '_projected'
arcpy.Project_management(in_data, out_data, spatial_reference)
grid_projected = out_data
## (ii) Transforming into the layer of centroids
centroids_name = geography + '_centroids'
arcpy.FeatureToPoint_management(grid_projected,	gdbPath + centroids_name, "CENTROID")
centroids_projected = gdbPath + centroids_name
## (iii) Latitude and longitude
#arcpy.AddGeometryAttributes_management(centroids_projected, "POINT_X_Y_Z_M")
fieldnames = ['GRID_ID']
outfile = output_dir + "Amman_zarqa_latlon.txt"
if arcpy.Exists(outfile):
    arcpy.Delete_management(outfile)
    arcpy.ExportXYv_stats(centroids_name,fieldnames,"COMMA", outfile, "ADD_FIELD_NAMES")
# Step 3: Delete unnecessary xml files
directory = output_dir
file_list = os.listdir( directory )
for file in file_list:
    if file.endswith(".xml"):
        os.remove( os.path.join( directory, file ) )
In the ../input/travel_time, I can't see the file "Amman_zarqa_latlon.txt". What can be the reason for this ?
Thanks, in advance
Tags (1)
by Anonymous User
Not applicable
I don't see where you are creating the dataset with the 'zarqa_nh_centroids' name in your original code so was it changed?
Going off the original code- Is 'centroids_projected' variable used anywhere? Is that supposed to be the input for the ExportXYv instead of 'centroids_name', which I don't think is in the working_dir/ env.workspace so you would have to use the complete path to it (i.e. 'centroids_projected' instead of just using the files name.
by Anonymous User
Not applicable
Have you tried using the debugger and seeing what arcpy.Exists() does? Does it even reach the arcpy.ExportXYv()? You could comment out the arcpy.Exists conditional to test it (or try os.path.exists() since it’s a text file your checking for and nothing specific to gis) and run the script.
esmao
Hi, JeffK. I commented out it as you said, but still I don't see any output file in the output directory.
Also, I put print() right before arcpy.ExportXTv() . it actually doesn't reach there.
Do you have any suggestion? Thanks
by Anonymous User
Not applicable
If its not reaching there then you need to find where the script is failing.  Set a breakpoint near the beginning of the script and step through your code's execution.
esmao
I revised the code a bit, after checking indentations (corrected line 57). Now im getting the error.
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Feature Class: Dataset zarqa_nh_centroids does not exist or is not supported
Failed to execute (ExportXYv).
Do you have any idea what is going on ? Thanks!
by Anonymous User
Not applicable
esmao
I see, I just noticed that. Your suggestion that using centroids_projected solved the problem. Thanks a lot!
