Objects in this class cannot be updated outside an edit session
27815
02-07-2014 06:53 AM
JordanParfitt
I keeping getting the "Objects in this class cannot be updated outside an edit session" error message. I can't figure out why because it seems to be I'm opening an edit session. Is there a step I'm missing?
Thank you in advance.
 arg_sdeDEV_sde = "Database Connections\\[email protected]" ARG_ACCESS_OPENING = "Database Connections\\[email protected]\\ARG.DistributionSystem\\ARG.ACCESS_OPENING" ACCESS_OPENING_Layer = "ACCESS_OPENING_Layer" Reconcile_Versions_Log = ""   # Process: Make Feature Layer tempEnvironment0 = arcpy.env.workspace arcpy.env.workspace = "Database Connections\\[email protected]" arcpy.env.overwriteOutput = True arcpy.MakeFeatureLayer_management(ARG_ACCESS_OPENING, ACCESS_OPENING_Layer, "", arg_sdeDEV_sde, "OBJECTID OBJECTID VISIBLE NONE;OPEN_TYPE OPEN_TYPE VISIBLE NONE;REC_INFO_NAME REC_INFO_NAME VISIBLE NONE") arcpy.env.workspace = tempEnvironment0  # Process: Start Edit edit = arcpy.da.Editor(arcpy.env.workspace) edit.startEditing(True, False) edit.startOperation()  # Process: Select and Update Data cursor = arcpy.UpdateCursor(ARG_ACCESS_OPENING) for row in cursor:     row.setValue("STRUCTURE_ID", row.getValue("ENCLOSURE_ID"))     cursor.updateRow(row)
JordanParfitt
I created a new SDE connection with the default version pointing to the version I wanted to edit, eliminating the need to change versions pro grammatically. Hope this helps someone else.
-Jordan
NeoGeo
startEditing ({with_undo}, {multiuser_mode})
for with_undo, start session without an undo/redo stack for versioned data
for multiuser_mod, use False for unversioned data
If your sde layer is versioned, you might try
edit.startEditing(False, True)
JordanParfitt
When I do edit.startEditing(False, True) it breaks on that same line and I get the error "Operation only allowed by the owner of the version [SDE.DEFAULT]"
It's almost like it's not changing the version when I execute this:
# Process: Change Version
arcpy.ChangeVersion_management(ACCESS_OPENING_Layer, "TRANSACTIONAL", "ARG.ARG_PARENT", "")
JordanParfitt
I should mention this is my new code, I added the change version piece:
# Set the necessary product code
import arceditor
# Import arcpy module
import arcpy
for row in cursor:
JordanParfitt
-Jordan
JoshuaBixby
MVP Esteemed Contributor
Reply moved and started as a new question since issue isn't ArcPy or Python related.
