hi all,
Am looking for a python code to find the nearest feature (street layer) for any given point (x,y) on the map.
i need to return the feature id only.
#python #arcpy
ArcInfo level license: use the Near tool.
Basic level license: perhaps start with a spatial join and go from there?
Best Regards,
Jim
Thanks a lot Jim.
the near tool will add fields to the layer used, am looking for another way which will return only the FIDs so i can loop through them and read information.
something like featurecursor interface in arcobjects.
thanks again for your replay.
Generate Near Table. Put the table in-memory and then use a cursor to loop through it looking for FIDs. The original table stays intact.
Thanks Joshua ,
i tried the tool, it does not take a point object (it needs a feature layer as an input). i need to let the user input the point coordinates in order to search the nearest feature and return its information.
unfortunately the two methods (near_analysis, generate near table) are not helping.
thanks
You can use a point they created. It sounds like you need to code the ability for a person to enter a point first then run one of those two analysis options.
As is the case with most geoprocessing tools, the in_features can be ArcPy Geometry objects in addition to feature layers. In your case, create a PointGeometry object for the coordinates you want, and then pass that point geometry as the in_features to the Generate Near Table tool.
Thank you Joshua , Dan and JIM
Finally i created the tool which without your suggestions i couldn't make it.
def Closest_RD_XY( X, Y, Near_FC , Meters 😞 try: SR = arcpy.SpatialReference(4326)# WGS84 GCS pntFC = arcpy.CreateFeatureclass_management("in_memory", "Acc_FC", "POINT", spatial_reference = SR)
# Just to check if layer created or not if pntFC is None: print "FeaClass 'Acc_FC' is not created" #------------------------------------------- In_curs = arcpy.da.InsertCursor( pntFC , ["SHAPE@XY"]) INValue = In_curs.insertRow([(X, Y)]) if INValue < 1 : print "point is not inserted" del In_curs
# use the near tool in arcpy arcpy.Near_analysis(pntFC, Near_FC , str(Meters)+ " Meters", "LOCATION","ANGLE","GEODESIC") S_curs = arcpy.da.SearchCursor(pntFC, "*") RD_ID = S_curs.next() # return all information of the nearest feature SN_curs =arcpy.da.SearchCursor(Near_FC, "*", "OBJECTID = " + str(RD_ID[2])) NFeature = SN_curs.next()
#delete in memory point layer arcpy.Delete_management (pntFC) return NFeature
except Exception as e: return "Error No Road found within 100 Meters 'Error ': " + e.message
Signed in members can post, follow updates, and more. New here? Register a free account.
