multiple definition query for multiple layers
1444
03-17-2024 04:47 AM
marklee1869
I need to write python code to apply definition query for all layers at once, i already tried some code which i insert it below but it makes a new layers
# Set the workspace (change to your desired geodatabase or folder)
arcpy.env.workspace = r"D:\abo-ammar\geoParcel.gdb"
# List of feature classes (change to your desired feature class names)
feature_classes = ["parcels_corner", "parcels_dimension", "LINE_AMLAK", "Parcels"]
# Define the common query expression (change to your desired query)
query_expression = "parcel_no = 2"
# Loop through each feature class and apply the definition query
for feature_class in feature_classes:
# Get the existing layer
layer = arcpy.management.MakeFeatureLayer(feature_class, f"{feature_class}_Layer", query_expression)
print(f"Definition query applied to {feature_class}.")
# Print a success message
print("Definition queries applied to all specified feature classes.")
i want to know how to apply the same code but over the current layers not with generation of a copy of each layer
Amir-Sarrafzadeh-Arasi
Dear marklee,
I hope you are doing well,
you just need to delete the "_layer" from your second element in the arcpy.management.MakeFeatureLayer function.
layer = arcpy.management.MakeFeatureLayer(feature_class, f"{feature_class}", query_expression)
Good luck
Amir Sarrafzadeh Arasi
