Model Builder calculate field expression
5871
11
03-16-2022 11:08 AM
2Quiker
I have a model that I would like to use the the following code to update a field "Permits" based on how many text occurrences are in "ParcelNum1" field based on the "PermitNum" field. I get the following error and need help figuring out what the issues is and all fields are text fields. I need this in model builder.
Example
OBJECTIDPermitNumParcelNum1Permits
1aa11231234512345, 12346
2aa112312346
3BB33616789167891, 67892, 37893
4BB336167892
5BB336167893
6UU98321112311123
7PP222569896988, 6989
8PP22256988
Pre-Logic Script code:
dict1 = dict()
with arcpy.da.SearchCursor('TableTest6',['ParcelNum1','Permit_Count','PermitNum']) as cursor:
    for row in cursor:
        if row[0] not in (None, "", " "):
            dict1.setdefault(row[0],[]).append(str(row[2]))
def concat(nf):
    x = None
    if nf in dict1t:
        x = ",".join(dict1[nf])
    return x
Permits = conact(!ParcelNum1! )
Error.
ERROR 000539: Runtime error
File "<string>", line 2, in <module>
RuntimeError: cannot open 'TableTest6'
Failed to execute (Calculate Field (4)).
RhettZufelt
MVP Notable Contributor
Funny, I thought I posted the below post earlier, but was still sitting as draft....
Still having issues with TableTest6.
have you tried hard coding the path to that table?
with arcpy.da.SearchCursor(r'C:\path2table\TableTest6',['ParcelNum1','Permit_Count','PermitNum']) as cursor:
You can open the python window from Catalog and enter each command one at a time.
Can print individual variable results, etc.  This can often give you more info on where it is failing.
R_
RhettZufelt
Documentation for model builder says that items in the drop-down (TableTest6) is a variable.
You could try putting it in the cursor as a variable instead of text:
with arcpy.da.SearchCursor(TableTest6,['ParcelNum1','Permit_Count','PermitNum']) as cursor:
and see if that works.
Otherwise, just hardcode the path and you are don.
R_
